Home > Forums > General Forums > CFD Freelancers
fluent-porous media
Like Tree4Likes
  • 1 Post By amir_hiwa
  • 1 Post By Muhammad Shad
Old   February 26, 2017, 14:18
Question fluent-porous media
amir ghasemi
amir_hiwa is on a distinguished road
hi every body i am working at heat transfer in porous media and a wanna to know can i simulate conjugate heat transfer in the porous zone using fluent.
thank u every body
Muhammad Shad likes this.
amir_hiwa is offline   Reply With Quote
Old   March 7, 2017, 05:31
mishal
Muhammad Shad is on a distinguished road
Send a message via Skype™ to Muhammad Shad
thank u every body
Yes you can simulate conjugate heat transfer in porous media by using material physical properties. after simulation you will used the corresponding temperature for heat transfer of different modes. thanks
amir_hiwa likes this.
Muhammad Shad is offline   Reply With Quote
Old   March 13, 2017, 12:56
amir ghasemi
first ,thanks for your response but in fluent we have to specify heat transfer cofficient for considering heat transfer. but what can i do if heat transfer cofficient be unknown??
Old   March 14, 2017, 01:15
mishal
well come, FLUENT can't calculate all parameters at a time. FLUENT will provide you some parameters and then carry out that parameters for further calculation manually. Create different surface within simulation control volume, just specified temperature at boundaries of your problem. after simulation and convergent solution FLUENT will provide you heat transfer coefficient and temperature distribution through out you flow domain. you can enter temperatures and heat transfer coefficient calculated by FLUENT in formulas of conduction and convection manually. FLUENT will just only provide you the temperatures distribution and heat transfer coefficient. you will then forward and use these values manually. i think this idea will help you. thanks
Old   March 14, 2017, 02:49
amir ghasemi
Thank u mohammad
I wish u always be happy
canjugate, porous media
porous media in FLUENT Natalie2210 FLUENT 7 August 15, 2019 13:46
porous media model validation Tensian FLUENT 0 September 23, 2016 06:04
analysis of multiphase and porous media in ansys fluent ahmed_khatibs FLUENT 0 November 4, 2014 13:01
Porous Media Simulation with CFX/Fluent Ghasem ANSYS 1 May 14, 2013 10:07
species mass source in porous media ? PK FLUENT 0 February 16, 2007 12:12
