Home > Forums > General Forums > CFD Freelancers
freelancer to be paid :Design of stirrer impeler using solidworks flow simulation API
Like Tree1Likes
  • 1 Post By Boris_M
Old   June 25, 2015, 18:46
Default freelancer to be paid :Design of stirrer impeler using solidworks flow simulation API
Idris
Edreez is on a distinguished road
The impeller(S) was modelled in solidworks and an existing fluid equation (code) is to be embedded into the solidworks flow simulation using microsoft visual studio.
Edreez is offline   Reply With Quote
Old   June 26, 2015, 10:35
Robert Strong
strongrj13 is on a distinguished road
i've worked with solidworks flow simulation before and it is notoriously not good for accurately predicting rotating impellers. I can help you out if you are open to working with Fluent or Autodesk Simulation CFD. We can still use the impellers you've modeled in Solidworks to use in those packages.
You can reach me at robert.strong@strongsimulationconsulting.com
Robert Strong.
strongrj13 is offline   Reply With Quote
Old   July 14, 2015, 07:18
Disabled
Boris_M will become famous soon enough
Hi Robert,
That is not correct. I assume your boundary conditions and mesh were not good enough. I know of our customers that use the software in automotive turbocharger industry and get very accurate results. Also in the aerospace industry. There was recently a benchmark done by a russian institute comparing our results against measurements and Fluent. See for yourself:
http://www.mentor.com/products/mecha...tor-simulation
Yes, that is a helicopter blade but the same accuracy we get for impeller in pumps as well as fans and other impeller like applications.
Regards,
Boris
daijo likes this.
Boris_M is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
Rotary Engine Combustion Simulation With SolidWorks Flow Simulator 2009 saaguy FloEFD, FloWorks & FloTHERM 9 December 7, 2010 21:55
SolidWorks Flow Simulation ericnutsch Main CFD Forum 0 November 17, 2009 22:44
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
