MPI Application rank 0 exited before MPI_Finalize() with status 1 |
November 11, 2015, 10:09 |
Deniz
Rep Power: 10 |
Hi, i'm trying to run a 1-cylinder hcci simulation on my laptop. I chose average mesh size 0.0006 because it didn't let me chose a bigger size, this was the biggest value that program was able to achieve meshing.
I'm starting the simulation but it exits after 4-5 sec.s. I read from fla file as: Problem diverges: Scalar transport equation, variable: Species transport, material: 1 MPI Application rank 0 exited before MPI_Finalize() with status 1 Thanks a lot in advance. |
November 24, 2015, 08:02 |
Zvonimir
Rep Power: 10 |
It is hard to say? Could you upload *.fla file (or part of file at least)
November 24, 2015, 08:39 |
confusion in MPI mode
ali navid
Rep Power: 10 |
what should I write in colored boxes in MPI mode?
November 24, 2015, 08:44 |
Zvonimir
Rep Power: 10 |
not the screenshot of your FIRE application but the file with extension *.fla that is placed in your case. In this file the setup is written and I can find the problem of divergence. From my opinion is in wrong case setup... |
November 24, 2015, 09:05 |
different qustion
ali navid
Rep Power: 10 |
sorry
but my question was a different question I dont know what to write in selected box in MPI mode? what is difference of MPI mode with single mode? |
November 24, 2015, 09:17 |
Zvonimir
Rep Power: 10 |
For MPI different is only that you put n number of CPUs in (1 is single and 10 is eg. for 10). Your error that you get is from setup...
November 24, 2015, 09:40 |
paralleling computers
ali navid
Rep Power: 10 |
in order to make PC's in parallel case I have to just join them in to a network and enter their IP in host name?
is it enough? what should I write in username part? |
MPI application rank 0 exited before.. | jypark | FLUENT | 1 | July 15, 2016 12:58 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Problem running fluent with InfiniBand | blackpuma | FLUENT | 10 | August 28, 2011 01:16 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 10:54 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 11:12 |
