Autodesk CFD or SW Flow Simulation for Electronics cooling |
June 22, 2018, 09:45 |
Naresh Yathuru
Rep Power: 11 |
Hello Everyone,
It has been a while since I posted in CFD online. I am looking for experts suggestion. For electronics cooling (mostly conjugate heat transfer) which is most suitable in terms of: 1. Less elements but still predict heat transfer from fins accurately in otherwords predict thermal resistance of heat sinks accurately. 2. Robustness 3. Stability Thank you in advance. Best regards, Naresh Yathuru |
June 25, 2018, 05:07 |
Jon Wilde
Rep Power: 10 |
I work with Autodesk so am of course biased and can in fact only comment on our solution.
We should have no issues here though, should be pretty simple. That is about all I can say, give it a go |
August 9, 2019, 15:15 |
#3 | |
Rep Power: 16 |
Forget about Autodesk. It is expensive, unreliable and buggy especially when you deal with relatively complex models. SW Flow simulation is much better option for electronic cooling especially if you use SW as your 3D mechanical package. The best option however in my opinion would be HeatDesigner or scStream from MSC Inc although they will be more expensive than SWFS (but cheaper than Autodesk CFD). P.S. I don't work for any software company and I don't use any of these packages anymore but used them extensively in the past when they were called CFDesign and Floworks. |
April 12, 2021, 05:42 |
SIMULATION OF MANNED SPACE RE ENTRY VEHICLE/schiaparelli capsule WITH CHEMKIN FILE
Rep Power: 5 |
I have struggled lot by referring the paper called AEROTHERMODYNAMIC ANALYSIS OF MANNED SPACE VEHICLE that is written by Author GUIZEPPA PELLAZA and ANTONIO VIVIANI.
They did this Simulation using ICEM-CFD toolbox and surface impact method(SIM) BY CIRA.I have to compare this paper results with ANSYS FLUENT toolbox.Eventhough I give Proper boundary conditions from this paper and implementing Chemkin file,Iterations are not starting.What Can I do with simulation of this MPS using Chemkin file?I HAVE ATTACHED THE CASE FILE WHICH I DID.I given boundary conditions like inlet,oultet and wall- pressure far field Space capsule-interior PRESSURE-1400pa Temperature-560k angle of attack 20 deg for space capsule Mach number-20 |
Flow Separation in GE frame 9 Compressor CFD simulation | chocolater | CFX | 1 | October 27, 2017 12:35 |
FLOEFD vs AUTODESK CFD SIMULATION | amarnath_sivasubramanian | Main CFD Forum | 0 | August 5, 2015 23:45 |
Revit and Autodesk Simulation CFD | Shljuki | Autodesk Simulation CFD | 3 | May 29, 2013 15:10 |
boundary condition for air-con in autodesk cfd simulation | payam1362 | Autodesk Simulation CFD | 1 | January 4, 2013 12:05 |
Numerical simulation of controlled cooling of forged crankshaft using cfd | chaudhariph | FLUENT | 0 | April 29, 2011 06:07 |
