licence server error
Like Tree2Likes
  • 2 Post By sagar041
Old   March 31, 2012, 11:34
Default licence server error
Atique
Atique is on a distinguished road
i installed ansys 14 and when i open mechanical APDL launcher it gives the error
could not connect to any license servers
This is fatal error existing. plz help me about that
Atique is offline   Reply With Quote
Old   April 1, 2012, 15:25
Harshit Dahiya
harshit is on a distinguished road
1.restart your computer.
2.delete licensing folder in program files/ansys14.0
3.reinstall license manager and provide it the license file or whatever way u r cracking it.
4. open license manager and you can check if Flexlm is running.
hope dis will help you.
harshit is offline   Reply With Quote
Old   May 23, 2013, 19:43
sagar
sagar041 is on a distinguished road
This might be the problem due to installing the ANSYS in different folder than the License Manager. All you have to do to fix it is copy all the files other than folders in the c:/program files/ansys inc/shared/licensing/ to x:/program files/ansys inc/shared/licensing/ where x is the drive where you installed your ANSYS products. Also make sure the port number in License Manager is same as the port no in license.dat. Use the default port 1055 to run ANSYS Mechanical APDL. Hope this helps.
lighter and saru44 like this.
sagar041 is offline   Reply With Quote
Old   May 30, 2013, 12:07
Mary Smith
marysm000 is on a distinguished road
Dear Atique,
I have the same problem. Have you find the solution?
marysm000 is offline   Reply With Quote
Old   September 2, 2014, 14:38
sash buz
lighter is on a distinguished road
Thanks sagar041
It worked for me.
lighter is offline   Reply With Quote
Old   September 17, 2014, 00:46
Rocky_Patel's Avatar
Rocky Patel
Rocky_Patel is on a distinguished road
I m getting error like following when i open ansys workbench
Can anyone help?
could not connnect to any licence srever.
the server is down or not responding.
ANSYSL_SERVERS:2325@Rocky-PC
FLEXlm server:1056@ROcky-PC
Rocky_Patel is offline   Reply With Quote
Old   December 15, 2014, 13:52
Default linces
Devendra choudhary
arjun425 is on a distinguished road
http://johnkaisercalautit.wordpress....-flexlm-error/
this is very useful ...try this
arjun425 is offline   Reply With Quote
Old   February 19, 2016, 03:44
Default Not able to open iges file in ANSYS
Sneha
sneha_00 is on a distinguished road
I have a licensed version of ANSYS 14.5 ( Academic Research ) i am trying to attach a model in workbench made in solidworks 13 (converted to .IGES) but the file is not getting attached in mechanical but is importing in design modeler there are about 1200 parts in the model but the model with less parts are getting attached and can be run properly. Can anybody please tell me the solution?
sneha_00 is offline   Reply With Quote
Old   September 19, 2016, 13:12
Default ansys license problem
Miguel
tius is on a distinguished road
I have installed ansys 15 in my w7 os computer and i have problem with license, but if i work without internet connection the problem is solved.
tius is offline   Reply With Quote
Old   March 22, 2019, 03:54
Saravanan
saru44 is on a distinguished road
Thanks. This solved my issue. I was having the same problem where the licenseing server is installed in C drive and Ansys products are installed in F drive. I wanted to install the license server also in F but it is not possible to change the default path in Ansys 15 licensing manager installation wizard! Now, after coping the contents from 'c:/program files/ansys inc/shared/licensing/' to 'F:/ansys inc/shared/licensing/', all ansys products are working fine
saru44 is offline   Reply With Quote
Old   December 4, 2020, 03:43
Unhappy Host id is not valid
  #11
Saiyed Tasnim Md. Fahim
Location: Obninsk Institute for nuclear power engineering
stfahim is on a distinguished road
When I try to add a license file, "the host id is not valid" this message shows up." How to solve this issue? I have tried 6-7 times by uninstalling and installing and even changing the pc name, but still no effect.
stfahim is offline   Reply With Quote
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 06:17
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
user defined function cfduser CFX 0 April 29, 2006 11:58
