October 19, 2011, 08:58 |
Problem with Volumes Gambit
Evangelos
Rep Power: 15 |
Hello !
i have creates two volumes(create real brick).These volumes are side by side (the side of a volume is glued to the side of the other volume) when i try to merge the volumes i see a message that says that "Error: Volume volume.X can not be merged with other volume(s) (it is disconnected)" When i try to create the volumes with edges everything is ok!(because i take the face of the first volume as the face of the other) can i connect the volumes without change the drawing ? |
October 19, 2011, 09:20 |
Maxime Perelli
Rep Power: 41 |
you have 2 common faces superposed.
Then connect the 2 surfaces, it won't merge your 2 volumes. But after connecting you will be able to merge the volumes. PS: There is a subforum dedicated to Ansys Mesh: http://www.cfd-online.com/Forums/ansys-meshing/ You will have more chance to get a quick reply
In memory of my friend Hervé: CFD engineer & freerider |
problem importing mesh into gambit | tsm554 | FLUENT | 7 | December 3, 2010 23:15 |
Problem importing solidworks to gambit | holyo | ANSYS Meshing & Geometry | 3 | April 16, 2010 06:16 |
Problem with Gambit | Diego | FLUENT | 0 | July 5, 2007 04:30 |
Startup Problem in Gambit 2.2 with WindowXP | Win Win Maw | FLUENT | 3 | January 25, 2006 12:09 |
problem in CFX solver about isolated volumes | Yuan | CFX | 2 | August 16, 2004 23:54 |
