Natural Convection Boundary Conditions, tips or advise needed ! |
September 27, 2010, 18:44 |
Logan Page
Rep Power: 16 |
Hi
I am masters engineering student and I'm currently trying to recreate the first part of results from a journal article: "Constructal multi-scale cylinders with natural convection" by T. Bello-Ochenda and A. Bejan, in FLUENT. Simple put its a row of parallel, horizontal, cylinders (diameter Do) with a constant wall temperature (Tw) cooled by natural convection analyzed in 2D. The current computation domain that i have setup for FLUENT is made up of: 1) a symmetry plane/edge on the left cutting through the middle of a cylinder 2) a symmetry plane/edge on the right cutting through the middle of the spacing (So) between 2 of the cylinders 3) a pressure inlet at the bottom edge (P = 0, T = 0) 4) a pressure outlet at the top edge (P = 0, T = 0) 5) and a cylinder wall (no slip, no penetration, Tw = 1) The governing equations have been non-dimentionalised and the input parameters for a Rayleigh Number of 1000 for FLUENT are as follows: - Do: 1 - Fluid density: 37.268 (boussinesq approximation) - Fluid Cp: 0.72 - Fluid thermal conductivity: 1 - Fluid viscosity: 1 - Fluid thermal exp. coeff.: 1 - Operating pressure: 0 - Gravity: -1 (Y dir) - Operating temp.: 0 - Specific operating density: 37.268 Using this model, FLUENT converges nicely for a given upstream (Hu) and downstream (Hd) length from the cylinder, but when i do a grid independence study i find that as i increase the downstream length (Hd) the heat transfer density rate continues to increase (ie there is a chimney effect created). Does anyone have any suggestions / ideas on how to modify the boundary conditions to eliminate this effect? |
boundary conditions, cylinders, natural convection |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
Natural Condition Boundary Conditions | Felix | FLUENT | 5 | January 26, 2007 22:30 |
Natural Ventilation Boundary conditions | lmitsc | FLUENT | 0 | October 2, 2006 12:24 |
boundary conditions for natural ventiliation room | tong | FLUENT | 0 | January 14, 2006 07:33 |
Natural convection and periodic boundary layer | George Thomas | FLUENT | 0 | August 29, 2005 11:12 |
