Fluent 12 Animation
Like Tree1Likes
  • 1 Post By AranyiPatricia
Old   July 28, 2010, 15:13
Default Fluent 12 Animation
sahm's Avatar
Seyyed Ali H.M.
sahm is on a distinguished road
Does anyone know how I can define an animation in fluent12 for a unsteady case? I know how to do it in fluent 6, but in fluent 12 menus are changed.
sahm is offline   Reply With Quote
Old   August 3, 2010, 06:33
Arányi Patrícia
AranyiPatricia is on a distinguished road
Hy!
I'm trying to do this right now, but something is still wrong (but I gues not the animation is the reason)
Theoretically:
-->initialize the solution first
-->then: calculation activities-->solution animations-->create/edit
don't forget to switch the interval to "every timestep"
Somehow I still have some problems, but I hope in your computalions it's going to work. Please tell me if it's OK, cause it will help me
Regards,
Patrícia
Farzam likes this.
AranyiPatricia is offline   Reply With Quote
Old   November 5, 2010, 18:45
NormalVector's Avatar
NormalVector
NormalVector is on a distinguished road
I'm guessing you guys have figured it out and moved on already but here's my two cents:
Initialize solution and then go to calculation activities and choose Create/Edit under Solution Animations. Then activate a sequence and choose "time step" as "When." Then set up your storage type/display type settings.
Once the solution is done calculating, go to the Calculation Activities and then Create/Edit, edit your display type and then click "display." Now go back to Graphics and Animations and select Solution Animation Playback, then Setup. You can now replay your solution.
This is the way it has worked for me before but I haven't tried it recently. Also, when I wrote the playback to MPEG, the Temperature/Pressure scale on the left side of the display didn't show up. Dunno why.
NormalVector is offline   Reply With Quote
fluent 12.0, fluent animation error
Animation Error in Fluent Andrew FLUENT 9 October 1, 2020 17:42
Animation in Fluent jackr84 FLUENT 4 November 19, 2013 03:46
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
How create GOOD quality animation in Fluent ? maziboss FLUENT 7 November 22, 2009 06:57
ANIMATION with Fluent Luca FLUENT 0 June 6, 2005 05:13
