Flow field is not conformal, how to fix it?
Like Tree1Likes
  • 1 Post By evcelica
Old   March 30, 2023, 00:22
Default Flow field is not conformal, how to fix it?
XiaoS
1258748897 is on a distinguished road
Hey everyone,
As the fig.1 shows, there is a obvious boundary in the flow field. Fig.2 is the mesh I used. They are two bodies but they are conformal actually. I wonder how to make Fluent recognize them as a whole without merging them in DesignModeler.
Thanks a lot in advance
SongX
1258748897 is offline   Reply With Quote
Old   March 30, 2023, 16:38
Erik
evcelica is on a distinguished road
In Design Modeler, select all bodies, right click, and "create part". This multibody part will share nodes on the interfaces, acting as one meshed body.
Without doing this it just meshes the three bodies as completely separate bodies, and if you click on a line or face, there will be two lines or faces there, one for each body.
If you create part, there will only be a single line or face in between the parts, not two.
1258748897 likes this.
evcelica is offline   Reply With Quote
Old   March 30, 2023, 22:10
Thumbs up
XiaoS
Thank you a lot! It has figured out my problem!
Intuition for why flow follows convex surfaces lopp Main CFD Forum 47 February 1, 2022 14:14
OF v2006 overset tutorial: position of pressure reference changes flow field tecmul OpenFOAM Running, Solving & CFD 0 January 24, 2021 11:00
What is a fluctuation in flow field and how to generate fluctuation in flow field? ht2017 Main CFD Forum 2 November 3, 2020 21:41
rerun with same flow field, different fluid props Tim Phoenics 0 March 3, 2004 15:51
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
