March 19, 2023, 08:25 |
FSI, incompressible fluid, hyperelastic wall
Paul Ulmer
Hey everyone,
I am trying to perform a two way fluid-mechanical coupling. In Fluent there is an incompressible oil with one coupled wall. In mechanical this wall consists of a hyperelastic material. I am transferring a force and a displacement. My task is to drain the Fluidvolume and track the deforming wall. The problem is that a slight change in the fluidvolume leads to a massive pressure gradient. This is deforming my wall, which leads to an even higher volume change and higher pressure. In the end i receive the error highly distortet elements. I tried to lower the timesteps, i removed gravity, i changed my outlet to wall. As a result i have a complete static fluidvolume, but its still the same error. Everything works fine when i use air as my fluid (compressible, low viscoity). Do you have any suggestions? Maybe there is a way of transferring volume instead of force? Any ideas are more than welcome Thanks a lot in advance Paulmer |
fsi 2-way coupling, hyperelastic |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
