sliding mesh or dynamic mesh for transient simulation
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   October 28, 2022, 16:20
Default sliding mesh or dynamic mesh for transient simulation
zagros
zagros135 is on a distinguished road
hi everyone. i want to simulate an oscillating-pitching- airfoil in unsteady flow situation. which one of these methods do you think is good? sliding mesh or dynamic mesh? and why?
with regards.
zagros135 is offline   Reply With Quote
Old   October 29, 2022, 05:01
Gert-Jan
Gert-Jan will become famous soon enough
That depends on how your geometry looks like and the degrees of freedom it has.
With 2DOF, it can rotate around a fixed axis, put it in a cilinder.
With 3DOF, it can rotate around a point, put it in a sphere.
With 4DOF or more, it can also translate, then you require dynamic mesh.
zagros135 likes this.
Gert-Jan is offline   Reply With Quote
Old   October 29, 2022, 09:22
zagros
well my geometry is 2d. and i put it in a circle and use the udf to rotate. but the problem is that when I run it, inner zone flow moves in a circle at first.
Old   October 30, 2022, 07:31
Gert-Jan
This is 2DOF. Your wing can only rotate around a fixed axis.
But why is it a problem? Is the wing rotating to a neutral position? Shouldn't it do this? If not, then what do you expect? I can't read your mind.
And I don't know what is in your udf. Do you refer to the udf to describe the DOF? Or does it describe the wind fluctiations? Unclear to me........
2D Dynamic mesh simulation of a scroll expander louisdub11 CFX 96 November 15, 2021 17:54
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Dynamic mesh simulation artemiss1984 Main CFD Forum 1 August 11, 2010 14:11
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 03:37
