Fluent Meshing - different cell size for different volumes
Like Tree2Likes
  • 1 Post By MKuhn
  • 1 Post By MKuhn
Old   January 24, 2022, 08:42
Default Fluent Meshing - different cell size for different volumes
Moritz Kuhn
MKuhn is on a distinguished road
Dear all,
I would like to have a smaller cell size for a certain region in my model. For that region I defined an extra volume. But how can I choose a different "Max Cell Length" for this volume? Even if I choose smaller cells for the faces, the size of the cells in the middle of the volumes are almost the same. See attached picture. Has anybody any hints?
Cheers Moritz
Akimlav likes this.
MKuhn is offline   Reply With Quote
Old   January 27, 2022, 12:10
Thumbs up Via body size method
Moritz Kuhn
I found the solution. It is necessary to add another local sizing with a body size method to control the max size inside the specified volume.
See the attachment.
Akimlav likes this.
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets Struggle_Achieve OpenFOAM Meshing & Mesh Conversion 3 June 17, 2019 10:29
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? aja1345 ANSYS Meshing & Geometry 0 October 3, 2018 15:22
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 09:26
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Warning 097- AB Siemens 6 November 15, 2004 05:41
