August 31, 2021, 07:11 |
how to connect two separate outlets
Marcin
Rep Power: 13 |
Hello Im facing with problem
I have multiple inlets and outlet. The are separate geometrical. I need to coonect two outlets to make flow from them. Its good to make interface on these outlets or something else??
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
November 10, 2021, 05:48 |
Good question
Yes, this is an actual question for me now!
November 13, 2021, 07:03 |
Gert-Jan
Rep Power: 28 |
If you can get away with same massflow on inlet-outlet-combination and same massflow average Temperature and/or concentrations, then it is possible to do this in CFX using expressions. E.g., if the fluid entering through inlet 1 equals the conditions from Outlet1, then you can write:
MassFlowIn1=massFlow()@Outlet1 TempIn1 = massFlowAve(Temperature)@Outlet1 Remember, this ignores any profile information, which is probably not so important if the inlet and outlet are far away anyway. |
mpt_connect: errorThe fl process could not be started. MPI Application rank 0 exited | tjZDH | FLUENT | 3 | November 28, 2021 15:30 |
How to connect values between two separate walls | lrodrigues | FLUENT | 3 | January 28, 2019 11:36 |
Error in compute process - No Active Application | yetlyg | FLUENT | 8 | October 27, 2018 23:30 |
error: connect failed | destroy | FLUENT | 7 | March 18, 2018 15:59 |
connect failed with errno%3d113 | wedsall | OpenFOAM Running, Solving & CFD | 2 | November 3, 2008 05:17 |
