ANSYS Polyflow solution not converge due to viscosity |
June 22, 2021, 01:00 |
Tan Jun Ying
Rep Power: 5 |
I am working on non isothermal single screw extrusion. I import the material data from extrusion directory, so by default it is using Arrhenius law.
When I run it shows the solution is not converge. In the listing view, it shows the info as shown in attachment. So I change the viscosity to be not temperature dependent, then the solution can be converged. So there is any way to make it converge and in the same time take the temperature into account to determine the viscosity? |
July 2, 2021, 00:29 |
Problem solved
Tan Jun Ying
Rep Power: 5 |
Thanks all, problem solved by create sub-model for temperature imposed on the plastic.
May 19, 2022, 02:31 |
Ansys Polyflow solution not converge due to considering viscosity dependence on temp
Punjab
Hello dear,
Hope you will be fine. I am facing same problem, which you had faced earlier. I have strucked here. I am working on Non-Isothermal PE-100 pipe extrusion. I am unable to create sub-model for temperature. Kindly guide me in this regard. Thanks in advance. |
Solution does not converge with temperature-dependent density - chtMultiRegionFOAM | Unkinunki | OpenFOAM Running, Solving & CFD | 5 | September 8, 2024 14:14 |
UDF for Automatic Solution Initialization for previous case data file | gartz89 | Fluent UDF and Scheme Programming | 6 | March 30, 2020 07:38 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
Solution not convergin in ansys workbench static structural | amit2590 | Structural Mechanics | 1 | May 16, 2014 17:19 |
