March 28, 2021, 23:39 |
Udf
Select
I am trying to write a UDF that relates the diameter to the viscosity through an empirical equation. Viscosity will be continuously changing along the segment's length.
The geometry is 3D irregular geometry (cannot be defined by a function). Maybe if I used the area-averaged velocity I can find the diameter? Any help on how to find the area-averaged velocity to use it in the UDF function? |
area-averaged velocity, average diameter, udf |
udf for one dimensional linear motion based on force | maccheese | Fluent UDF and Scheme Programming | 2 | September 1, 2019 03:18 |
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 13:43 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 01:53 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
