Fluent + mechanic
Like Tree1Likes
  • 1 Post By woodwax
Old   February 24, 2021, 14:43
Default Fluent + mechanic
Valaki Valami
woodwax is on a distinguished road
I would like to simulate a Peltier module with two heatsinks. One in cold and second in hot side. The cold side will be held at 280 K. Iam curious how the current through Peltier affects the temperature on the second, hot side.
The Peltier module I modelled in the Thermal-electric Mechanical solver.
The Two heatsinks are modeled in Fluent (because later I would like to change one heatsink to water cooler).
I have a problem with the two way data transfer between Ansys mechanic and Fluent. My current settings are:
Peltier hot side -----------> Heat Flow ----------> Heatsink on hot side
Heatsink on hot side -----> Temperature -------> Peltier hot side
Peltier cold side ----------> Heat Flow ----------> Heatsink on cold side
Heatsink on cold side ----> Temperature -------> Peltier cold side
Is that a correct data transfer between solvers?
cobal likes this.
woodwax is offline   Reply With Quote
CFX vs. FLUENT turbo CFX 4 April 13, 2021 09:08
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 03:48
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
