January 16, 2020, 20:37 |
ANSYS Thermal-Structural Analysis
Rep Power: 6 |
I am fairly new to ANSYS and am trying to use it to solve an assigned thermal analysis problem. I have a cylindrical plug of stainless steel with a smaller cylinder of ceramic coaxial inside it. I am to study thermal expansion of this assembly where one end of the cylinder is at STP and the other is heated to 200 C. I have meshed the geometry, executed a static thermal simulation with those temperature conditions, and fed the results into a static structural analysis in workbench. I applied a fixed support BC to the round face of the cylinder, while the flats are free to expand outward. The stress magnitudes I am getting for this set-up seem excessive--my maximum principle stress reaches hundreds of MPa, exceeding the yield stress of either material. The Von Mises stress is even greater. I have consulted tutorials online for similar problems and I have seen similar stress magnitudes without comment from anyone else. It just doesn't at first glance make sense--on the face of it, both steel and alumina should be able to take a measly 200 C without failing. I checked my material properties and they seem consistent with MATWEB and other sources. Is my BC (the fixed support) not the right one to use? Or am I misinterpreting my results somehow, and I am not actually breaking the material? Thank you. |
January 16, 2020, 22:40 |
Svetlana Tkachenko
Rep Power: 15 |
Do you have any reference data to compare your results against? For example, from past literature.
January 21, 2020, 13:18 |
Erik
Rep Power: 23 |
Why are you using a fixed support? Is that where your stresses are high? Why not let the assembly expand freely? (Using weak springs)
If you want to fully constrain the model, you have 6 degrees of freedom you must constrain. Figure out how to constrain the model, while still allowing free thermal expansion or shape change. HINT: constrain 3 points in a plane, call it an XY plane. Constrain all 3 points in Z, 2 in Y, and one in X. Figure out which 3 and which 1 would allow free thermal expansion |
January 22, 2020, 20:31 |
#4 | |
Rep Power: 6 |
But still, I applied a frictionless BC to one side to prevent motion in one axis (call it Z, so that X is the axis of the cylinder and Y is the other orthogonal direction). I have never tried weak springs before--how do they relate to free thermal expansion? There is an additional complication I've encountered this week, and which explains a great deal of my problems--the default "bonded" contact is unrealistic. In truth, since steel expands faster than ceramic, there should be *no* stress on the ceramic cylinder because a gap should form between it and the steel around it. But that requires me to switch to a "rough" contact condition--which requires more constraining to converge the simulation (still no luck there). Regarding your six points...I'm not sure where to start with that. Again, defining X as my cylinder axis, Z as the direction toward the distant fixed support, and Y as the other orthogonal direction, I just don't see which points should be constrained. Shouldn't all points be able to move freely in all three directions in free thermal expansion? I suppose I could constrain three points on the "hot" face of the cylinder, at 0 degrees, 90 degrees, and 180 degrees--don't allow them to expand toward the heat source. That's one axis taken care of (X). The assembly is not totally radially symmetric, though--there are other cylinders bored into the assembly, not radially symmetrically. So I don't think I can just take my 0-degree and 180-degree points and constrain them in Z for symmetry. So I'm at a loss here. |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 16:18 |
Acoustic Analysis using Fluent and ANSYS mechanical | ankit1512 | ANSYS | 0 | November 10, 2013 19:46 |
Best package for Thermal analysis similar to Muses | lmbgm | ANSYS | 2 | April 5, 2011 11:18 |
Short Course: Computational Thermal Analysis | Dean S. Schrage | Main CFD Forum | 11 | September 27, 2000 18:46 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 11:18 |
