Coanda Effect
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   October 8, 2019, 04:58
Default Coanda Effect
Henrike
Henrike01 is on a distinguished road
Hello, everybody,
I'm about to simulate a Coanda nozzle. However, speeds of up to 1600 m/s always occur in the narrow gap, which does not agree with the corresponding literature. On the left side is the inlet with a boundary condition of 0 bar pressure, on the right the outlet with a boundary condition of 0 bar and from above the air flows in with a pressure of 6 bar.
Does anyone have any idea what I can change in the simulation that the velocity significantly decreses?
Best regards
Henrike
Henrike01 is offline   Reply With Quote
Old   October 8, 2019, 05:06
BlnPhoenix is on a distinguished road
What kind of speeds are you expecting?
What kind of solver are you using (transient or steady state)?
Is the solver crashing?
What about mesh resolution in the narrow gap?
BlnPhoenix is offline   Reply With Quote
Old   October 8, 2019, 05:10
Henrike
I expect speeds of about 50-70 m/s.
I am using a steady state solver SST.
No, the calculation converges.
The mesh in the narrow gap should be okay as I have 5 Inflation layers.
Old   October 8, 2019, 05:28
Ok. Can you use a velocity inlet instead of pressure inlet?
Have you checked that 6 bar inlet pressure is correct? It looks like your inlet pressure may be too high for your expected speeds.
Old   October 8, 2019, 05:30
Henrike
Unfortuatley, I have to use a pressure inlet.
Even with 2 bar the velocity is about 500 m/s which is way too high.
Old   October 8, 2019, 05:33
Can you give rough estimate of mass flow and gap diameter?
Old   October 8, 2019, 05:42
Henrike
The gap has a width of 40 µm and the mass flow should be around 0.25 m^3/s.
Old   October 8, 2019, 07:16
Gert-Jan
Gert-Jan will become famous soon enough
If you look in standard literature you will find that when the pressure ratio Pin/Pout >2 (absolute pressures, for air, atmospheric conditions) the velocity will be around Mach=1=340m/s. So for a ratio of 6, your results look fine. Provided you have compressible conditions.
If you expect 50-60 m/s then your pressures are incorrect, or you are dealing with a multiphase system.
BlnPhoenix likes this.
Gert-Jan is offline   Reply With Quote
Old   October 10, 2019, 05:22
Henrike
Thank you for your reply. Can you name the literature that you are referring to?
Old   October 10, 2019, 05:45
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Which fluid are you trying to simulate? Air? Water? Something else?
Are you using compressible or incompressible fluid in the solver?
How did you ensure that the results we are discussing here are actually from a converged solution?
flotus1 is offline   Reply With Quote
Old   October 10, 2019, 05:47
Henrike
Hello I am simulating air that is incompressible. I also carried out simulations were the air was modelled as compressible but also there the velocities are a lot higher than expected (800 m/s).
Old   October 10, 2019, 07:57
flotus1's Avatar
Alex
So that answers the first part of my question. For air you absolutely need a compressible formulation for this type of flow. E.g. the compressible ideal gas model.
Now back to the ignored part of my question: are you absolutely certain that your solutions are converged? How did you check for convergence?
Edit: and what's the speed of sound in the fluid you are simulating?
maybe related: Supercritical outflow from an orifice
coanda, nozzle
Setup for a 2D Coanda Effect UAV on CFD Erfann FLUENT 0 May 8, 2017 10:15
Coanda Effect to produce lift. Austin Main CFD Forum 4 May 23, 2011 08:51
Coanda effect, condensation on sphere technophobe Main CFD Forum 4 February 17, 2010 11:04
Coanda effect nacaairfoil Main CFD Forum 11 October 23, 2009 08:11
coanda effect Craig Robbins Main CFD Forum 5 September 9, 1998 00:21
