February 20, 2019, 16:24 |
Mesh Quality - ICEM CFD
Asees Aamir
Rep Power: 8 |
My question is related to the mesh quality generated in ICEM CFD.
What is the minimum quality (as shown in ICEM) required for solution? If mesh is of bad quality, will the solution diverge or it will converge (continuity criteria 10^-5) to a wrong result? Which quantity (like skewness, aspect ratio etc) is the most important measure of quality? |
February 21, 2019, 03:39 |
M
Rep Power: 13 |
Hard to tell which is the actual minimum to get a good solution, I think it depends also a lot on the the physics incoporated into your setup.
I usually check the "quality" measure in ICEM to be above 0.1 (which is quite bad already from a visual check) and CFX can still handle it. Sometimes even bit smaller values. Idk about Fluent or some other solver. |
ansys, icem cfd, mesh generation, mesh quality |
[ICEM] Imporving Hexa mesh quality in ICEM CFD | Far | ANSYS Meshing & Geometry | 0 | February 3, 2018 07:45 |
[ANSYS Meshing] Generating Hexa-Core with ICEM CFD Interactive | dawdybishop | ANSYS Meshing & Geometry | 1 | October 31, 2017 21:50 |
ICEM 12 CFD help creating volume mesh from stl | EmpError | ANSYS | 0 | November 13, 2010 07:38 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 07:46 |
