Calculating force of nozzle using cfd-post?
Like Tree3Likes
  • 1 Post By AtoHM
Old   January 15, 2019, 11:21
Question Calculating force of nozzle using cfd-post?
Roh
Roh is on a distinguished road
Guys,
Monthes ago, created this topic:
Why I cannot calculate the thrust of my nozzle?
But can I use CFD-Post to calculate the thrust?
Take a look at this screenshot:
I think we can use the calculator of CFD-post. look at the setted options. Using function "Force" we can calculate the force (Pressure + Momentum) on each boundry(for me I have four boundries named as inlet,outlet1,outlet2 and outlet3) and then we can plus all of the forces to obtain the thrust force of the nozzle. Am I right? Are all of my discriptions correct?
Here is a link to discription of Function Calculator:
https://www.sharcnet.ca/Software/Ans.../NHFIFMEM.html
And here you can see:
The magnitude of the force vector on a boundary.
Supports “[<Phase>.]” and “@<Location>”.
See force.
And finally more details on force:
https://www.sharcnet.ca/Software/Ans.../i1308522.html
Roh is offline   Reply With Quote
Old   January 25, 2019, 06:58
M
AtoHM is on a distinguished road
I looked at the calculation in the other thread you linked. The approach to sum the momentum over your domain makes sense, however, it seems you completely neglected the pressure present at the solid walls.
Using the CFD results it should not be too hard to get your desired value.
Roh likes this.
AtoHM is offline   Reply With Quote
calculating force on moving vehicle panand01 Main CFD Forum 0 March 5, 2016 14:04
static enthalpy calculation in CFD Post newbie384 CFX 2 March 22, 2014 08:28
User CEL Function and CFD Post chastain CFX 4 September 24, 2013 14:58
CEL mathematical functions in CFD Post Jonathan CFX 9 November 5, 2012 09:37
Poly lines in CFD Post ashtonJ CFX 0 December 2, 2010 03:46
