./runwb2
exception inside UnhandledException handler: The type initializer for 'System.Console' threw an exception. [ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Console' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.ConsoleDriver' threw an exception. ---> System.Exception: Magic number is wrong: 542 at System.TermInfoReader.ReadHeader (System.Byte[] buffer, System.Int32& position) [0x0002b] in <a79e78aef2044b2abf7520c5f76ff5bc>:0 at System.TermInfoReader..ctor (System.String term, System.String filename) [0x00065] in <a79e78aef2044b2abf7520c5f76ff5bc>:0 at System.TermInfoDriver..ctor (System.String term) [0x00058] in <a79e78aef2044b2abf7520c5f76ff5bc>:0 at System.ConsoleDriver.CreateTermInfoDriver (System.String term) [0x00000] in <a79e78aef2044b2abf7520c5f76ff5bc>:0 at System.ConsoleDriver..cctor () [0x00062] in <a79e78aef2044b2abf7520c5f76ff5bc>:0 --- End of inner exception stack trace --- at System.Console.SetupStreams (System.Text.Encoding inputEncoding, System.Text.Encoding outputEncoding) [0x0000a] in <a79e78aef2044b2abf7520c5f76ff5bc>:0 at System.Console..cctor () [0x000a8] in <a79e78aef2044b2abf7520c5f76ff5bc>:0 --- End of inner exception stack trace --- at Ans.Program.Executable.DisplayError (System.String errorMessage) [0x00000] in <8334d254a0bf40a181200885e7f67034>:0 at Ans.Program.Executable.HandleUnhandledException (System.Object sender, System.UnhandledExceptionEventArgs e) [0x00044] in <8334d254a0bf40a181200885e7f67034>:0 |
Gert-Jan
Rep Power: 27 ![]() |
maybe you can find some help here: ANSYS Workbench on "Uncertified" Linux Distros
#3 | |
Stanislav Pechmann
Rep Power: 0 ![]() |
#4 | |
Rep Power: 14 ![]() |
Hey.. I am facing the same error. Do you know a solution? Code:
[WS2-RGD-JB Linux64] $ echo $TERM xterm-256color Edit: Found it. Code:
export TERM=xterm |
Rep Power: 8 ![]() |
same error too.
ok, it strongly depends on the Linux distributions.
It works well on my OpenSUSE Linux leap 15.1. I also tried other versions, such as centos and ubuntu, non of it can support the workbench. so good luck to you. |
#7 | |
Rep Power: 7 ![]() |
ANSYS is not supported by non-enterprise linux distributions. Many errors appear when trying to install and run on Ubuntu, etc. |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 00:10 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
