Centrifugal Blower - CFD Tutorial - Multiple Reference Frame |
October 12, 2018, 01:49 |
mayur
Rep Power: 8 |
This tutorial illustrate the procedure for setting up and solving problem using the MRF capability. As an example, the flow field on a 2D section of a centrifugal Blower will be calculated. Although this is a general methodology that can be applied to cases where more than one reference frame is moving, this example will be limited to a single rotating reference frame.
This tutorial demonstrates how to do following..... 1. Create mesh interface. 2. Specify different frames of reference for different fluid zones. 3. Set the relative velocity of each wall. 4. Calculate a solution using the pressure - based Solver. https://youtu.be/nMcgNyoUGhU |
Centrifugal Blower - CFD Tutorial - Multiple Reference Frame | msp.16191@gmail.com | ANSYS | 0 | October 12, 2018 01:44 |
Moving reference frame for turbine simulation | Rahl141 | STAR-CCM+ | 2 | December 28, 2017 07:25 |
Multiple Rotating Reference Frame useful? | Jeremie84 | FLUENT | 6 | November 8, 2012 10:32 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 13:38 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 10:27 |
