Two simultaneous heat sources in ANSYS APDL |
August 26, 2018, 18:40 |
Fabrício
Rep Power: 8 |
I am currently working with a transient thermal analysis for a welding process. For this model, I use Goldak’s double ellipsoid heat source, which is defined using APDL commands. Geometry, mesh and timesteps are determined in Ansys Mechanical. In order to achieve a finger type penetration, I have to combine two heat sources. The problem is that I have not been able to combine them simultaneously. As a first trial, I have been trying to simulate two heat sources at different coordinate points. However, only one of them is applied. Does anyone know how to solve this problem? I have attached my APDL codes and some figures to give a better understanding. Thanks in advance. |
January 1, 2020, 23:04 |
use the different body
kipa
cut body ,one body add one source
February 5, 2020, 18:53 |
Juan Daniel Trejos
Rep Power: 6 |
¿Do you still need help about this topic? |
May 25, 2020, 11:05 |
Goldak's Double Ellipsoidal Heat Source
Shekhar S
Rep Power: 6 |
Hi All,
I have been trying to model the heat source and succeded for a single bead only. For 2nd bead, the modification in the code has not worked yet. Can you give me some lead? |
May 26, 2020, 19:04 |
Juan Daniel Trejos
Rep Power: 6 |
Hi, can you share your code, I like to check some errors or to give you some tips.
May 27, 2020, 03:56 |
Hi Juan
Shekhar S
Rep Power: 6 |
Here is my code for two moving heat source one after one:-
C*** CONSTANTS DEFINITION VOLT = 175 ! VOLTAGE (VOLTS) CURR = 12.5 ! CURRENT (AMPERES) EFF = 0.90 ! EFFICIENCY VEL = 4E-3 ! WELDING SPEED (m/s) Q = EFF*VOLT*CURR ! HEAT INPUT (W) A = 5E-3 ! ELLIPSOID DIMENSIONS (m) B = 2.5E-3 C1 = 8E-3 C2 = 10E-3 FF = 0.6 ! HEAT FRACTIONS FR = 1.4 TAU = (C1/VEL) ! LAG FACTOR (s) TTIME = 65 ! TOTAL TIME (s) !!TIME_WELD = 56 ! WELDING TIME (s) DT = 1 ! TIME INCREMENT (s) PI = 3.14 EE = 2.718 C*** HEAT SOURCE CMSEL,S,WELD_1 ! SELECT THE WELD COMPONENT *GET,EMAX,ELEM,,NUM,MAX ! GET THE MAXIMUM ELEMENT NUMBER *GET,EMIN,ELEM,,NUM,MIN ! GET THE MINIMUM ELEMENT NUMBER ALLSEL !!NPT = TIME_WELD/DT ! NUMBER OF LOADSTEPS 1 *DO,ii,1,28,1 WTIME = (ii/2) TIME,WTIME *DO,jj,EMIN,EMAX,1 CSYS,20 *GET,X,ELEM,jj,CENT,X *GET,Y,ELEM,jj,CENT,Y *GET,Z,ELEM,jj,CENT,Z CSI = Y + (VEL*(TAU-WTIME)) *IF,(TAU-WTIME),GT,0,THEN C = C1 F = FF *ELSE C = C2 F = FR *ENDIF PART1 = 6*(3**0.5)*F*Q/(A*B*C*PI*(PI**0.5)) PART2 = (EE**(-3*(X/A)**2))*(EE**(-3*(Z/B)**2))*(EE**(-3*(CSI/C)**2)) QF1 = PART1*PART2 BFE,jj,HGEN,,QF1 *ENDDO SOLVE *ENDDO CMSEL,S,Substrate_1 ! SELECT THE WELD COMPONENT *GET,EMAX,ELEM,,NUM,MAX ! GET THE MAXIMUM ELEMENT NUMBER *GET,EMIN,ELEM,,NUM,MIN ! GET THE MINIMUM ELEMENT NUMBER ALLSEL *DO,uu,29,60,1 WTIME = (uu/2) TIME,WTIME *DO,kk,EMIN,EMAX,1 CSYS,30 *GET,X,ELEM,kk,CENT,X *GET,Y,ELEM,kk,CENT,Y *GET,Z,ELEM,kk,CENT,Z CSI = Y + (VEL*(TAU-WTIME)) *IF,(TAU-WTIME),GT,0,THEN C = C1 F = FF *ELSE C = C2 F = FR *ENDIF PART3 = 6*(3**0.5)*F*Q/(A*B*C*PI*(PI**0.5)) PART4 = (EE**(-3*(X/A)**2))*(EE**(-3*(Z/B)**2))*(EE**(-3*(CSI/C)**2)) QF2 = PART3*PART4 BFE,kk,HGEN,,QF2 *ENDDO SOLVE *ENDDO CMSEL,ALL BFEDELE,ALL,ALL ALLSEL TIME,TTIME DELTIM,DT*51.jpg 2.jpg |
June 19, 2020, 18:50 |
Try CMSEL
#7 | |
Juan Daniel Trejos
Rep Power: 6 |
My apologies for the delay, Y had many troubles using command BF because APDL identified the nodes but the program warned that they were not selected. I tried many ways to fix this warning message and I did it with de CMSEL Command.
SF,NSURF,CONV,H,TAR CSYS,1000 CMSEL,S,NSPOT BF,ALL,HGEN,%BEAM% !SF,NSPOT,HFLUX,%BEAM% ALLSEL,ALL !SELECT ALL ENTITIES Quote:
July 15, 2020, 21:20 |
#8 | |
dharmik makwana
I think for that you have to named selection that bead component and change location value for in do loop for I,j,k may be it works |
May 24, 2021, 06:12 |
hi heat source required for pipe joint
#9 |
sivakrishna
hi everyone
I need a heat source for pipe joint welding please help me any for APDL GOLDAK heat source code thank you |
May 24, 2021, 06:13 |
please help me sir
#10 |
sivakrishna
May 24, 2021, 08:47 |
#11 |
Shekhar S
Rep Power: 6 |
Share your attempt with us. then we can help
ansys apdl, fem, heat source |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 04:17 |
Ansys Fluent analysis of heat exchanger | MStudent | FLUENT | 2 | April 20, 2015 09:40 |
Question about heat sources, 2D case modelling | thomas. | FLUENT | 0 | March 5, 2015 08:53 |
Ansys mechanical APDL problem. | russogianluca90 | ANSYS | 0 | October 13, 2014 08:38 |
Heat flux in ansys cfx | juliom | OpenFOAM Running, Solving & CFD | 2 | April 14, 2009 15:30 |
