Getting CFD Nusselt No to correlate with gnielinski theory |
January 28, 2018, 12:14 |
IMPORTANT PLEASE HELP!! Getting CFD Nusselt No to correlate with gnielinski theory
Jonathan
Rep Power: 8 |
Hi there
I am working on a project which is modelling smooth flow through a rectangular micro-channel. (The project does go further but for now this where I need help). I am trying to obtain a Nusselt number that correlates with the use of Gnielinski theory but thus far I have had little success. I am trying to find htc by doing q/(Twall-Tbulk) but I don’t understand at what point I should take the temps and how I should. I have entered a heat flux BC. I am using k omega SST model. I am using ANSYS fluent and their post. If anymore info is needed just ask Last edited by jonheb; January 28, 2018 at 16:02. Reason: recieved no answers |
February 16, 2018, 21:33 |
Rahul
Rep Power: 11 |
For example, if you want to calculate Nusselt number at a surface, you need to find Twall- max temp at that point in a surface and Tmean-Avg temp at the surface
You can use your temperature contour to estimate at which point max temp occurs.Later, in CFD post you can create a point by specifying the co-ordinates of that point. Then create a expression maxVal(Temperature)@Location(in our case specify the point) For mean temperature, areaAve(Temperature)@Location(in our case specify the surface) Cheers! |
March 2, 2018, 12:23 |
Jonathan
Rep Power: 8 |
Hey there
I'm trying to get Nusselt for in the centre of the channel flow. In Fluent I have been drawing a line across the wall and using surface integrals, area weighted average, wall temp for Tw and then for the Tb I go into post and draw a plane at the same location of the line from above and then areaave temp plane. I have a constant heat flux of 50000 The problem is these results aren't even close to what the Gnielinski correlation says I should be getting. |
fluent |
CFD Meshing Theory. Where can I read something more??? | Stabum | Main CFD Forum | 4 | October 26, 2012 07:48 |
is there any money in CFD? | T | Main CFD Forum | 35 | May 9, 2001 20:35 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 8, 1998 09:19 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 3, 1998 09:45 |
salary range | Frank Muldoon | Main CFD Forum | 7 | August 3, 1998 20:04 |
