relationship between wrap angle and blade angle
Like Tree2Likes
  • 1 Post By wwenj815
  • 1 Post By subodh_12
Old   January 8, 2018, 05:34
Default relationship between wrap angle and blade angle
wenjie wang
wwenj815 is on a distinguished road
I use Bladegen to generate an centrifgual impeller. when I modify the balde angel distribution (Bezier curve), the wrap angle distribution is also changed. i refer to the document and the function between the wrap angle and blade angle is tan(beta) = r*d(theta)/dm. Could anyone provide more details about the function?
ssmacae likes this.
wwenj815 is offline   Reply With Quote
Old   April 5, 2019, 14:25
Subodh Ranjan
subodh_12 is on a distinguished road
Hi there!
A bit off-topic, could you tell me how to determine the wrap angle. I have calculated the basic impeller dimensions, ie,
1. Meridional velocities at impeller inlet and exit
2. The diameter of the impeller at the inlet and exit
3. The diameter of the hub at the inlet
4. Inlet vane angle
5. Outlet vane angle
6. RPM and hence the peripheral velocities at the inlet and outlet
How do I calculate the wrap angle now?
I'm using BladeGen to generate the impeller but I cannot accurate do it unless I have this
ssmacae likes this.
subodh_12 is offline   Reply With Quote
beta angle, bladegen, impeller, wrap angle
Wrap Angle for Impeller shraman Main CFD Forum 1 April 5, 2019 14:27
[BladeModeler] Bladegen Radial Impeller Wrap Angle - Help Required surajkashyap ANSYS Meshing & Geometry 1 April 5, 2019 14:24
Calculating blade metal angle Marc_Re Mesh Generation & Pre-Processing 0 July 3, 2017 11:09
Centrifugal Pump: Blade Lean Angle? shelmak ANSYS Meshing & Geometry 4 August 10, 2016 17:44
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance barak182 ANSYS Meshing & Geometry 2 August 18, 2010 04:07
