Journal command for multiple case file read, and store data of static pressure along
Like Tree1Likes
  • 1 Post By divergence
Old   February 24, 2017, 23:12
Default Journal command for multiple case file read, and store data of static pressure along
Ash Kotwal
Ash Kot is on a distinguished road
Journal command for multiple case file read, and store data of static pressure along axis.
How to do it?
Thanks,
Regards,
Ash.K
Sent from my iPhone using CFD Online Forum mobile app
Ash Kot is offline   Reply With Quote
Old   February 28, 2017, 04:40
Ash Kotwal
How to do it?
Thanks,
Regards,
Ash.K
Also is it possible to know, what Journal commands should I use to do following tasks
1. Read case
2. Initialize
3. Run for certain iterations
4. Save case and data file.
5. Read same case and data file
6. Save data/plot of static pressure along axis, in excel file
7. Again step 1 with new file.
Thanks, Please.
I'm kinda noob with journal commands, although I can figure out most of FLUENT.
Old   July 7, 2017, 23:59
Omar jumaah
jumaah is on a distinguished road
Hey, try to learn how to use TUI commands. Once you be able to do all case's steps (monitor, initialize, solve, etc) using TUI command, e.g,
/define/boundary-conditions/bc-settings/mass-flow
then create a journal file. File -- scripting -- record journal ( all steps as commands and orders, save and close will be recorded ). To re-read, file- scripting-- run script file.
hope it will help.
Jumaah
jumaah is offline   Reply With Quote
Old   July 10, 2017, 04:08
divergence is on a distinguished road
You can also create a journal by simply writing things like
into a (for instance) notepad file, which can be saved as a .jou format and then read into Fluent as a journal.
jumaah likes this.
divergence is offline   Reply With Quote
UDF: How to load data from an external file into a vector EmiS Fluent UDF and Scheme Programming 17 January 14, 2019 02:55
UDF macro to read the name of the case file polaritus Fluent UDF and Scheme Programming 2 March 23, 2015 05:59
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
