November 25, 2016, 11:22 |
Error in Fluent
iran
Rep Power: 10 |
Hello
I have an error in ANSYS workbench at fluid flow (fluent). First error : Error: Cortex received a fatal signal (unrecognized signal). Error Object: () Error: cx-enable-item: wta[1](Widget) Error Object: #f When select calculate in part of set up, seen it. And then second error when close window set up seen it. Error: cx-show-item: wta[1](Widget) Error Object: #f What do I do for solve this error? Thanks |
March 11, 2017, 11:59 |
The same
Sergio Contreras
Rep Power: 9 |
Hey did you resolve the problem?
I have now exactly the same I dont now what to do. Because this hapend I do not know what to do, because this happens only for some models. The same model, does not deliver said error, but if you change it folder, then if you deliver it It's strange It also does in old models that used to work well |
March 12, 2017, 02:34 |
iran
Rep Power: 10 |
unfortunately,I couldn't solve it.
and I see it for all project that i'm calculating. I don't know reasons that this happened until solve it. |
March 17, 2017, 05:06 |
Mehak
Rep Power: 9 |
Try to define UDF(USER DEFINE FUNCTION A C++ CODE) it is a enhanceing feature
Sent from my ASUS_Z00LD using CFD Online Forum mobile app |
March 18, 2017, 12:10 |
iran
Rep Power: 10 |
Do i define for velocities inlet or the other things?
thank you of answer |
March 18, 2017, 12:13 |
Mehak
Rep Power: 9 |
March 18, 2017, 12:20 |
iran
Rep Power: 10 |
thanks a lot, surely i'm testing it. i hope this error be solved.
April 18, 2017, 06:05 |
Patel Brijesh
Rep Power: 10 |
My project on shell and tube type condenser. In simularion choose Eulerian two phase model with k-e turbulent model. For cold water inlet give mass flow rate inlet condition and pressure outlet. Hot fluid also give mass flow inlet and pressure outlet condition. Here in condenser inlet and inside vacuum pressure so , at inlet given initial gauge pressure given -91000pa and outlet gauge pressure given -95000pa.
When I start Simulation (steady state), happens this :<br /> <br /> First error :<br /> Error: Cortex received a fatal signal (unrecognized signal). Error Object: () Then start the simulation again without problems, but throw this message previously: Error: cx-enable-item: wta[1](Widget) Error Object: #f Finaly , when the calculation finish without problems, or when I stop it, second Error: Error: cx-show-item: wta[1](Widget) Error Object: # Please give some suggestion..thank you. Sent from my Lenovo A7020a48 using CFD Online Forum mobile app |
April 20, 2017, 06:27 |
#9 | |
iran
Rep Power: 10 |
another guidance is using of UDF function, but I didn't test it yet. |
April 20, 2017, 09:27 |
#10 | |
Patel Brijesh
Rep Power: 10 |
April 21, 2017, 06:01 |
#11 |
iran
Rep Power: 10 |
I'm sorry, I don't know.
You can try another way and use of UDF, maybe solve this error. |
November 8, 2017, 00:31 |
#12 |
Vignesh Lakshmanan
Rep Power: 10 |
Hi All,
I get this error in fluent. I am using a UDF to define temperature time dependance as a boundary condition. Error: cx-show-item: wta[1](Widget) Error Object: #f I cannot understand what it is. Also, my UDF does not calculate the required temperature profile after few time steps |
November 8, 2017, 11:48 |
#13 | |
Lucas Barreto
Rep Power: 9 |
November 9, 2017, 01:05 |
#14 | |
Vignesh Lakshmanan
Rep Power: 10 |
Error: Cortex received a fatal signal (unrecognized signal). Error Object: () and at the end of the calculations I got the Cortex error. WHat I did was interpreting the udf again, this time no error while initialising and at the end of calculation !!! Strange But solved |
December 6, 2018, 05:15 |
#15 |
Adam Venter
Hi all
I was able to resolve this issue by starting the fluent case file using the windows SDK command prompt Goodluck! |
November 9, 2019, 22:50 |
Solved this error by slightly changing mesh
#16 |
Gavin Amos
I changed zero settings in fluent, merely changed by 503,000ish element mesh to a 507,000ish element mesh - a tiny tweek - and the error went away and the calculation proceeded correctly, as within 1 second of calculated flow time my thrust values were within 5% of industry thrust data from APC prop.
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 09:08 |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 03:48 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
