April 22, 2016, 12:52 |
Turbogrid to Fluent for Rotor and Stator
Sara Wong
I am trying to design an axial compressor within Ansys. I used Bladegen to create two files, one rotor and one stator, which I then individually meshed in Turbogrid. Now I have two files which I need to combine and get into fluent so I can analyze the compressor with a sliding mesh. I can't get both files into the same Fluent case. Can someone please explain if there is a way of doing this? Thank you in advance. |
September 23, 2016, 23:18 |
Have a nice time!
Rep Power: 11 |
Hello, have you solved the problem?
fluent, turbogid |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
batch mode fluent - beginner | CompIng | FLUENT | 1 | November 30, 2015 12:48 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
