Maxwell External Circuit Editor
Like Tree1Likes
  • 1 Post By MaxwellUser
Old   January 18, 2016, 20:14
Default Maxwell External Circuit Editor
Connecticut
MaxwellUser is on a distinguished road
The attached circuit was exported as a .sph file then uploaded as an external circuit to a Switched Reluctance Motor in Maxwell. The circuit runs on a 170 v constant voltage source. The six windings receive current when the switches close. The switches is set to a full second delay before closing. No current should run through the motor during that second, however, the transient current plot on Maxwell shows the current pulsing through the windings at a value of around 40 amps during that second.
The SRM has no magnets, changing flux, or initial currents/voltages. There should not be current running through the motor. Is the circuit set up/imported correctly?
Thank you for your help!
File Type: jpg MaxwellExternalCircuitEditorScreenShot.JPG (60.0 KB, 21 views)
JONGHLEE likes this.
MaxwellUser is offline   Reply With Quote
circuit, current, editor, external, maxwell
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
Can't get data from OpenFoam to external solver using externalCoupled perry OpenFOAM Running, Solving & CFD 4 May 26, 2014 09:09
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
Using external text editor Praveen. C CFD-Wiki 0 September 16, 2005 05:53
Temperature Distribution on a circuit board Blackadder Main CFD Forum 1 March 27, 2003 12:32
