ANSYS ICEPAK Transient simulation - waveguide thermal analysis
Like Tree1Likes
  • 1 Post By Jupudi.pramodh
Old   September 11, 2015, 09:46
Default ANSYS ICEPAK Transient simulation - waveguide thermal analysis
Chris
chris92jc is on a distinguished road
hey guys,
I went through the transient simulation chapter (chapter 13)on the ansys icepak tutorial. I am designing my own experiment but whenever i run the solution it jumps from a temperature of 20 to 4326 in 1 second and then for the next 18 seconds it stays as 4326..obviously something is wrong here but i cant seem to figure out what.
attached is an image of my design, and below are some details of my design.
description:
- simulation from 0.0 - 20.0s
- increments of 1s
- source power (100W)
Later on i will be designing heat sinks on top of the source to see the convection effect but first i want to see how the the two different heat sources interact with each other.
cheers guys.
chris92jc is offline   Reply With Quote
Old   October 13, 2015, 09:11
Default Hi
Pramodh.J
Jupudi.pramodh is on a distinguished road
Send a message via Skype™ to Jupudi.pramodh
Hi Chris,
Greetings.
First of all I'd like to know what is the flow condition. Natural convection/ forced convection. In natural convection that too a transient problem, without heat-sink/ heat spreader, I think the source temperatures going very high seems sensible. I suggest, first try simulating the same case in steady state environment and see what are the temperatures observed. Then you can switch to Transient. Also I think 1 sec time step seems a little huge. Try to re iterate the same using a combination of time step size and iterations per time step. Always make sure that your model is converging for each time step. Time step of the order of 0.05 Sec would be a good number to start with. .
Instead of a fixed time step size, you can try different options available in setup.
muzammil likes this.
Jupudi.pramodh is offline   Reply With Quote
ansys, convection, icepak, transient analysis, waveguide
analysis the photovoltaic thermal collector (PV/T) by Ansys and Radiation modle ali.alshamani FLUENT 0 March 16, 2014 01:40
Resume Transient simulation HMR CFX 1 June 28, 2011 22:13
Transient Thermal Analysis in Ansys Workbench khurram1 ANSYS 0 November 22, 2010 03:40
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 18:46
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
