How to make periodic two faces of identical surface and different mesh |
September 6, 2015, 04:00 |
Rep Power: 14 |
Hallo, I'm running the CFD analysis of an impeller.
I have made a tetrahedral mesh without imposing an identical mesh in the two periodic surfaces of the flow channel. I have succeeded in running the analysis in OpenFoam, (it interpolates the two different surface mesh). Now I would like to do the analysis in Fluent, using the same mesh. I have tried to make the surfaces periodic using the command mesh/modify-zones/make-periodic, however it reports me: Warning: Number of elements does not match between zone 12 and 13. Error: Failed to make zones periodic. Error Object: #f It there another command to interpolates the surfaces and make them periodic? Thanks in advance, Dmaz |
September 7, 2015, 17:08 |
Alex
Rep Power: 49 |
There should be an option for a periodic interface in the "interfaces" tab. This type does not require identical mesh topology on both sides.
