FSI continuity defect
Like Tree1Likes
  • 1 Post By stumpy
Old   February 2, 2015, 08:41
Default FSI continuity defect
Martinw is on a distinguished road
Hello all,
Im trying to simulate a Fluid-Structure-Interaction with Ansys Workbench 15.0. The fluid part with CFX and the structural part with ANSYS (Transient Structural).
The model has 3 parts:
1. The fluid domain (water) a tube with d=10mm and a length of 100mm
2. The Top Membrane a Shell-Element (structural, steel) with d=10mm and a thickness of 0.25mm
- the first Fluid Solid interface
- with a defined displacement:
0 [s] = 0 [m]
2.e-005 [s] = 0 [m]
7.e-003 [s] = 1.e-003 [m]
1 [s] = 1.e-003 [m]
on the center (a circle with d=1mm) only in Z-direction, longitudinal to the tube.
3. The Bottom Membrane also a Shell-Element (structural, steel) with d=10mm and a thickness of 0.25mm
- the second Fluid Solid interface
- it will be deformed due to the fluid forces.
So the tube is closed by the 2 Shell-Elements. The 2 Shells are deforming.
Analysis type: Transient
Total time: 10ms
Time steps: 1e-06s
My Problem:
The solution shows a large continuity defect, like you can see in the chart and picture.
http://www.directupload.net/file/d/3886/hift2yq4_png.htm
Chart 1: traversal node displacement, blue top membrane, red bottom membrane
http://www.directupload.net/file/d/3886/xb8m5r6t_png.htm
Picture 1: Time: 10ms, Displacement scale x8
Im already try to decrease the Conservation target (10e-02 to 10e-04), Residual target (10e-04 to 10e-06) and the Expert Parameter: max Continuity loops from 1 to 5. This steps were showing no significant difference.
Have somebody experience with that kind of FSI simulations and have an idea to solve this problem?
If someone needs more information about the model, it would be a pleasure for me to describe it more in detail.
Thanks for the help!
Best regards,
Martin Wisniewski
Martinw is offline   Reply With Quote
Old   April 1, 2015, 17:37
stumpy is on a distinguished road
For a closed deforming domain you need to use a compressible fluid to maintain mass conservation. So you need to define your water density to be a function of pressure, e.g:
Pref= 1 [atm]
BulkMod= 2.2e9[Pa]
Density = 998[kg/m^3]*(1 +(Absolute Pressure - Pref) / BulkMod)
Once you combine this with FSI it will be really unstable. Look on the ANSYS customer portal for Solution 2022119 to see how to stabilize.
Daniel_Khazaei likes this.
stumpy is offline   Reply With Quote
ansys, cfx, conservation target, continuity, residual target
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
