CFD Simulation of Exhaust Gas Dispersion into Atmosphere from Industrial Stack
Like Tree1Likes
  • 1 Post By Mehul Patel
Old   January 23, 2015, 08:36
Default CFD Simulation of Exhaust Gas Dispersion into Atmosphere from Industrial Stack
Mehul Patel - CFD Expert
Mehul Patel is on a distinguished road
The objective of CFD simulation of exhaust gases emitting from industrial stack, for investigation of SO2 dispersion into atmosphere.
Solution:
Exhaust gas analysis was performed to investigate the SO2 dispersion in the atmosphere from the industrial stack. A wind profile was developed using UDF (User Defined Functions) to replicate actual atmospheric conditions. The simulation results showed the dispersion of the SO2 along with other species in to the atmosphere within the 500m radius from the stack.
Full Case Study at:
Kummi likes this.
Thanks,
HiTech CFD - CFD Analysis Services Provider.
http://www.hitechcfd.com/
Mehul Patel is offline   Reply With Quote
Old   February 22, 2017, 01:34
Default Your guidance to simulate same by using OpenFOAM
Anu Gupta
AnuGupta is on a distinguished road
HI,
I have seen your post on gas dispersion from an industrial stack, I really impressed with the study which you have performed. I would like to perform similar study as a part of my Ph.D work but with pollutants from the industrial stack. It would be great if you could help me in setting up the experiment in OpenFOAM.
Thank you.
With Regrads.
AnuGupta is offline   Reply With Quote
Old   March 12, 2018, 03:11
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Hello Mehul Patel,
Hope you are doing good..
Currently my project is same with respect to your topic. Could you please help me with my query posted in link below.
Flare Gas Dispersion into Atmosphere from Industrial Stack with effects of radiation
Thank you
Kummi is offline   Reply With Quote
cfd analysis, cfd simulation, exhaust gas analysis, exhaust gas dispersion, so2 dispersion
Boundary conditions for gas dispersion case DarrenC FLUENT 0 April 10, 2014 06:26
Ideal gas v.s. Real gas for wing simulation Anna Tian Main CFD Forum 1 December 16, 2013 12:39
Gas dispersion in air error message redhoax OpenFOAM Running, Solving & CFD 27 October 25, 2013 06:31
Gas plume or flare simulation ahourri FLUENT 0 November 14, 2005 10:23
Reactor simulation using CFD takes to the Internet Mark Brennan Main CFD Forum 0 April 16, 1999 06:57
