how to show array over the steamline in CFD-post
Like Tree2Likes
  • 2 Post By mjgraf
Old   May 31, 2013, 02:19
Default how to show array over the steamline in CFD-post
Astio Lamar
asal is on a distinguished road
Hello everybody.
I want to know if it is possible to show the direction of streamlines by some sort of array?
thanks.
asal is offline   Reply With Quote
Old   June 1, 2013, 21:41
mjgraf is on a distinguished road
Not sure what you mean by an array?
you could create a vector plot using the streamline and set to use arrowheads if you want to see the direction.
Originally Posted by asal View Post
Hello everybody.
thanks.
mjgraf is offline   Reply With Quote
Old   June 3, 2013, 06:02
Astio Lamar
Hello and thanks for your reply.
But the arrowheads are not Coincident exactly the streamlines. there is no any other solution?
Old   June 3, 2013, 10:38
Did you set the Vector location to the streamline?
Old   June 3, 2013, 17:34
Astio Lamar
Hello
How can I do this? I have Plotted both in over the same face
Old   June 3, 2013, 23:01
Create a streamline from any location you desire (surface, plane, polyline, etc.).
Create a vector using the streamline as the Location and configure as you desire.
That's it.
Now, if you are going for a very specific type of look, then we need a bit more of a description or example.
Hello
Gert-Jan and Wasi10 like this.
Old   June 4, 2013, 06:09
Astio Lamar
Dear mjgraf
Thanks for your time and reply.
I follow this:
First I plot the 2D streamline over a surface "streamline 1". them I plot a vector by the following properties:
Locations "streamline 1"
But by choosing the streamline as location, no vector shown over the streamlines.
Moreover I try to use the Symbol tab of streamline to show the Arrow head from there, but the problem there is that, there is no option to plot symbols tangentially since the streamline is plotted in 2D.
thanks.
Old   June 4, 2013, 09:07
From what you are now describing, it seems you are performing a surface restricted streamline on a WALL. This adds a little twist. The vector must be changed to use Conservative Boundary Data.
Also, a streamline by definition is tangent to the velocity vector of the flow.
Dear mjgraf
I follow this:
thanks.
Old   June 5, 2013, 20:05
Astio Lamar
Hello!
So is there any solution in the case? why when I want to plot arrowheads over the stramline location, nothing shown?
Old   June 5, 2013, 20:41
try checking the normalize button in the vector size.
the method I provided is the solution. either you are doing something wrong or there is an oddity with your setup.
Hello!
Old   June 6, 2013, 06:00
Astio Lamar
Hello.
I use the method that you mentholated, you can see the results in the attached figures. But I am looking for the plot exact same as you attachment.
Old   November 30, 2016, 14:41
mao
mao
mao is on a distinguished road
hi, i meet the same problem , have you fixed it ? thank u
mao is offline   Reply With Quote
Old   March 2, 2021, 17:26
Wasi
Wasi10 is on a distinguished road
That's it.
how can i draw arrows over the streamlines? could you pls suggest me a procedure?
Wasi10 is offline   Reply With Quote
calculating output parameter in cfd post markus67 CFX 3 August 26, 2015 10:28
Setting the desired Zoom level in ANSYS CFD Post for custom reports shreyasr CFX 1 July 11, 2013 02:57
Cfd post Manish Kumar ANSYS 2 February 22, 2013 01:29
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 07:21
post graduate opportunity in CFD application in Military teguhtf Main CFD Forum 0 January 31, 2011 22:30
