ANSYS Workbench and Maxwell
Like Tree1Likes
  • 1 Post By No|Yes
Old   May 12, 2013, 12:18
Default ANSYS Workbench and Maxwell
No|Yes is on a distinguished road
I have a project of Maxwell. I want to import it to Workbench. But my Workbench v14 somehow doesn't support mxwl. I have seen many tutorial, they said simply using "FIle/import/ *.mxwl" but it didn't work on me. As you see, mxwl doesn't show on list:
Do you know why? Did I miss something?
Are there any other way to link Maxwell to WorkBench? Thanks
h.emami1373 likes this.
No|Yes is offline   Reply With Quote
Old   May 24, 2013, 01:35
OK> I gave up on it. Now I try to use Thermal-Electric to analyse a coil when we have 10A current which run through it. But it always show this error:
"The analysis is not valid with the current geometry."
Maybe because I didn't know how to chose geometry??
This is my geometry
Old   May 27, 2013, 12:48
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Not an expert in this kind of analysis. But yout problem appears to be under-constrained with only 1 potential (voltage).
That is why there is a question mark next to "steady state thermal electric conduction"
Try adding a second potential to the opposing face.
flotus1 is offline   Reply With Quote
Old   May 27, 2013, 14:34
Thanks.
Anyway,for the first post. I solved it.
You need install ANSYS 13 first, then install Mawell 14 (or ANSYS 14.5 and Maxwell 16). In process of installing Maxwell, you have a option that connect ANSYS and Maxwell.
Old   March 28, 2014, 11:54
Default DO you know how I can connect Maxwell 16 to Ansys 15?
amir_aj67 is on a distinguished road
is there anyway that i can use Maxwell 16 in Ansys 15 workbench? it just does not appear as an option in the toolbox!
amir_aj67 is offline   Reply With Quote
maxwell
