[ICEM] Multiple Blocks in one Project
Like Tree2Likes
  • 2 Post By Far
Old   April 17, 2012, 15:21
Question Multiple Blocks in one Project
Eezyville's Avatar
Chris
Eezyville is on a distinguished road
Send a message via Skype™ to Eezyville
OK so I'm on the road to mastering this software and I've just started my trip. I'm working with a geometry for practice that has three separate parts in it. I want to block mesh those parts but they are not connected at all so I need three different blocks. How can I create three separate blocks that do not depend on each other? When I do make more than two blocks the software asks me if I would like to merge or replace the current block. If I replace then the work I've done is gone but if I merge then it changes the parameters in the first block. How do I use multiple blocks?
Eezyville is offline   Reply With Quote
Old   April 17, 2012, 16:37
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Yes it can be done. But I cannot understand what you want to achieve with disconnected blocks? Could you please explain your problem little more?
Split main block into six blocks and delete every other block with delete permanent option on.
Far is offline   Reply With Quote
Old   April 17, 2012, 21:53
Eezyville's Avatar
Chris
I don't completely understand how to use the program. I'm new to this block meshing concept. In this problem I just have 3 separate parts that needs to be meshed and these parts aren't next to each other. They are basically randomly placed and I'm using them to get familiar with the software.
Old   April 17, 2012, 22:38
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
can you post pictures of your geometry ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 18, 2012, 10:01
Eezyville's Avatar
Chris
I don't think I'm allowed to post pictures because of possible ITAR restrictions.
Old   April 18, 2012, 12:58
Far
Sijal
we wont download those pics. Promise.
diamondx and DungPham like this.
Old   April 20, 2012, 10:25
Far
Sijal
You can send them privately.
blocking strategy
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
[snappyHexMesh] Meshing multiple blocks Hanno OpenFOAM Meshing & Mesh Conversion 3 February 17, 2011 13:14
