[ICEM] Meshing an irregular geometry
Like Tree1Likes
  • 1 Post By cdegroot
Old   March 2, 2012, 15:42
Default Meshing an irregular geometry
Fabio Tabacow
Fabio Tabacow is on a distinguished road
I have a ""stl file" that it is a irregular geometry, and with ICEM CFD I saw that I can import this file to this software, but now, I have a problem....How can I build the mesh in my geometry????
I was reading the guide, and apears some doubts.... I need to make a surface to build the mesh or I can build the mesh only with this geometry???
sorry about the english..heheh...
Thank you!
Fabio
Fabio Tabacow is offline   Reply With Quote
Old   April 7, 2012, 07:50
jm2011 is on a distinguished road
You can use the blocking method or an unstructured mesh (eg octree) to mesh a STL surface, similar to other file formats. Just extrude the curves on the edge of the surface to create a volume if that's what you need. What do you mean by irregular though?
jm2011 is offline   Reply With Quote
Old   April 7, 2012, 17:01
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
I have meshed several stl surfaces successfully. For a complex surface (i.e. anything biomedical or resulting from some kind of scan of a physical object) your best bet is to use an Octree mesh. If you are using for CFD you should then delete the volume elements, smooth the surface mesh, and generate a Delaunay volume mesh. You can then smooth the Delaunay mesh if desired. Also, it is typically a good idea to "build topology" before you start meshing. However, for a complex surface this usually leads to a lot of curves that don't really capture any geometric features. Delete any such curves before meshing. Also delete any extraneous points.
Azy likes this.
cdegroot is offline   Reply With Quote
Old   July 2, 2012, 15:25
Fabio Tabacow
Irregular geometry in my case, is the geometry of a real artery......
I have de surface of an abdominal aortic aneurysm..... I will try to do what you said.....
I built the topology to have some curves and points, and all curves and points have the same part of the surface.........How can I move this curves for the new part that I created?
Thank you for the help!!!
Old   July 2, 2012, 15:34
Fabio Tabacow
The geometry that I'm working at is the picture that I attached...
Old   May 7, 2014, 16:58
Azy
Azadeh Saeedi
Azy is on a distinguished road
you know, I saw the same as you described in the manual. I tried it out many times and it didn't work. but the way you said it, it works! thanks alot
Azy is offline   Reply With Quote
Old   May 7, 2014, 17:03
cdegroot's Avatar
Chris DeGroot
That's great. I'm glad it worked for you!
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry robbierich90 ANSYS Meshing & Geometry 0 October 30, 2011 14:12
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 27, 2011 00:25
[ANSYS Meshing] Help - Meshing 2 Surfaces On A 2D Geometry Ali_M ANSYS Meshing & Geometry 4 March 29, 2011 04:01
[snappyHexMesh] Irregular mesh generation for simple box geometry ajl42 OpenFOAM Meshing & Mesh Conversion 0 March 7, 2011 18:04
[Other] Geometry and Meshing Questions Flaky ANSYS Meshing & Geometry 6 October 8, 2010 02:10
