[ANSYS Meshing] Extruding 2D mesh to 3D mesh in ANSYS meshing
Like Tree1Likes
  • 1 Post By sarangdalne
Old   February 6, 2012, 10:01
Default Extruding 2D mesh to 3D mesh in ANSYS meshing
Rachit Prasad
Rachit is on a distinguished road
Hi everyone,
I have been working on a 2D flow over an airfoil in fluent. I had generated the mesh in ANSYS meshing tool. It was an unstructured quad dominant mesh. Now, I have been told to extend the problem in 3D by extruding the same surface mesh in the z direction to convert it into an volume mesh. How could this be accomplished? I know a surface mesh can be extruded in ICEM CFD, but I have been told to do it for the same mesh, so it has to be done in ANSYS meshing only.
Thanks in advance!
Regards,
Rachit
Rachit is offline   Reply With Quote
Old   March 27, 2012, 03:40
amanbearpig is on a distinguished road
Has anyone come up with a solution to this issue? I am having the exact same problem. I can figure out how to extrude a 2D mesh in ICEM to 3D quite well, but how can I do this in Ansys Meshing? Thanks!
amanbearpig is offline   Reply With Quote
Old   March 30, 2012, 09:55
Matthias Voß
mvoss is on a distinguished road
i´ve managed to do so by creating a swept mesh,and set the source and target face manually. this means you have to redo ALL your meshing steps at the source face ... so maybe this isn´t what you were looking for.
neewbie
mvoss is offline   Reply With Quote
Old   March 30, 2012, 23:58
Sarang Dalne
sarangdalne is on a distinguished road
I guess you have created a sheet/surface model for your analysis. When in the meshing application expand the geometry tree node.. go to the body of interest, now in the details view of that body there must be a field of thickness. give whatever you want.
Thanks,
Sarang
dhruvism likes this.
sarangdalne is offline   Reply With Quote
Old   July 31, 2012, 07:03
Jordi
Jordi is on a distinguished road
Apparently, a surface can be meshed, a thickness specified and a 2D analysis performed. I'm only missing the possibilty of setting inflations...
Jordi is offline   Reply With Quote
Old   July 31, 2012, 07:32
Jordi
But I found it's possible to right-click on the meshing method, the select 'inflate this method' to select edges.
Old   February 14, 2024, 07:22
esha is on a distinguished road
can you please elaborate the steps?
esha is offline   Reply With Quote
Old   February 14, 2024, 08:49
Gert-Jan
Gert-Jan will become famous soon enough
Have you seen the dates?
Gert-Jan is offline   Reply With Quote
Old   February 14, 2024, 08:57
yes, any link with dates and new learners to ask. If you can elaborate then ok otherwise keep quiet please.
Old   February 14, 2024, 09:04
Gert-Jan
It is a matter of managing expectations.
Better start a new query with a well written up-to-date question than to expect people are still there after 12 years. Also, the software has changed significantly since then, so possibly they have a solution that doesn't work for you.
Old   February 14, 2024, 09:19
okay, thank you
2d meshing in ansys meshing syler3321 ANSYS Meshing & Geometry 10 November 1, 2012 21:42
How To save a created mesh file in Ansys Meshing ashtonJ CFX 4 January 7, 2012 23:04
ANSYS meshing help s.garg ANSYS 1 November 12, 2010 05:11
[Other] Ansys meshing - periodic mesh for fluent jsm ANSYS Meshing & Geometry 4 September 24, 2010 15:25
Problem importing ANSYS mesh, please help Ankan Kumar FLUENT 1 February 2, 2003 09:38
