January 31, 2012, 05:59 |
from total geometry to 1/4
Alessandra
Rep Power: 14 |
Hey! I have done a geometry 3D with DM, now my teacher ask me to do 1/4 of geometry.. do you know if there is a tool to cut 3/4 of geometry or if I have to make again?
Thank you |
January 31, 2012, 06:28 |
Tarik Bennani
Rep Power: 18 |
You can use the "Slice" tool to cut the geometry and keep the portion you want. You can slice by plane (if the default planes are not right for the kind of cut you want, you will have to create a new one), or by surface. Then DModeler will separate the geometry in several pieces (depending on the slice you will make) and you can keep the one you want. You'll have to be careful though, when you mesh, and when you define your boundary conditions. Does that answer your problem ? |
January 31, 2012, 09:03 |
Alessandra
Rep Power: 14 |
Thank you very much.. Well done
January 31, 2012, 14:05 |
Ali
Rep Power: 16 |
you can also define symmetry planes to cut 1/4th by making 2 planes and 2 sym.
Total pressure in CFX | famarcfd | CFX | 0 | June 17, 2011 11:33 |
car geometry | Arjun | FLUENT | 4 | September 1, 2007 16:08 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
Input Geometry from Ideas to Gambit | Knick | FLUENT | 2 | December 11, 2002 04:59 |
Virtual/Real geometry. | Jack Keays | FLUENT | 9 | June 16, 2000 00:39 |
