[ICEM] How to export geometry from icem
Like Tree3Likes
  • 3 Post By diamondx
Old   January 24, 2012, 07:05
Default How to export geometry from icem
Nick
Nick R is on a distinguished road
Hi all,
I find it much easier to create my geometry in ICEM rather than other CAD programs. However I have a problem with importing the geometry in proE (I need it for CNC machining). I usually save the file in the form of .3dm as it saves all the curves, surfaces etc. The problem is once I load the file in proE the surfaces dont appear properly at the edgesa although they look fine in ICEM. Is there a way to solve this ? Is there a way to created a solid in ICEM if you have a number of surfaces? Maybe that can solve my problem. I have tried other export format but they all miss the surfaces altogether. I have also played with tolerances to no avail. I'd very much appreciate your help. If I can't find a solution I'd have to go back to proE and sketch the whole thing from scratch!
Nick R is offline   Reply With Quote
Old   November 7, 2012, 03:45
Anon
vicky99 is on a distinguished road
We have the same problem too. We find it easy to the geometry on icem but the exported file doesn't form a solid in Solidworks. We would also need to use the model for CNC machining.
vicky99 is offline   Reply With Quote
Old   November 7, 2012, 11:53
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
icem cannot make solid. it's a surface based mesher. altough it has features to create geometry. it is limited to easy cases. it sure makes a good job importing them. if your case is easy, try exporting using step file in DESIGNMODELER. then perform a fill so you can extract a solid from your surface. i have tried STEP file from designmodeler to PRO/E, they work great.
Far, rsaha and metmet like this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 10, 2012, 04:20
Anon
we know that icem cant create solids. It is atmost expected that the exported surfaces from a solid in other solid modeling cad programs. Our geomerty is not an easy geometry.
Can't import geometry file from Icem CFD to Ansys Workbench Julien87 ANSYS Meshing & Geometry 1 July 19, 2011 17:50
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 01:51
How to Export ICEM mesh to ANSYS Structural SIVAPRAKAASH CFX 4 December 28, 2007 00:54
Exporting geometry from Solidworks to ICEM! Usman CFX 1 November 27, 2007 17:20
help, ICEM mesh export to ANSYS Fred CFX 3 June 28, 2007 14:51
