[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them.
Like Tree1Likes
  • 1 Post By vasava
Old   January 21, 2012, 20:10
Question Displaying solid domains in CFD Post without meshing them.
hda
hda is on a distinguished road
I am doing a 2D internal flow simulation. I want the enclosing solid domains to be visible in the post processing. For example, I need the wall thickness of a pipe to be visible, not only its inner boundary.
If I suppress the solid domains and mesh only the fluid ones, all I see in CFD Post are the fluid domains and their boundaries.
If I mesh both the solid and fluid domains, I see the solid domains grayed out in CFD Post. Great, but isn't there a way to avoid the unnecessary meshing of the solid domains?
How can we display solid domains in post-processing without actually meshing them?
Any ideas?
hda is offline   Reply With Quote
Old   January 24, 2012, 00:03
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
It is the mesh that is sent from the mesher to the solver, so no, I don't think there is any way around meshing those solid regions if you want to post process with them...
However, they could probably be meshed very coarsely if you were trying to reduce the size of the file.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   January 24, 2012, 00:21
hda
Thanks,
Yes, that's what I do now, a very coarse mesh.
I thought, in Workbench environment, solid domain data in Design Modeler could somehow be incorporated to CFD Post, without Mesher and Solver seeing those domains.
This could actually be a useful improvement to the software for visualizing complex enclosures without unnecessarily meshing them.
Old   October 20, 2016, 11:52
William
wilandlane is on a distinguished road
Has this been updated in any new version(s) of ANSYS? I would like to do the same thing as OP, visualize the solid body (non-interacting) around the fluid domain. This is easy to do in something like Solidworks, but I can't figure it out for CFD Post...
wilandlane is offline   Reply With Quote
Old   October 24, 2016, 08:33
Paritosh Vasava
vasava will become famous soon enough
You can create stl surface and import in CFD-post. Select File>Import>Import Surface or Line Data and in the drop-down menu you will see STL files option. Should be straightforward.
Edit:
This option is available V17 onward. I am not sure about older versions.
Edit:2
I checked and it is not possible for older versions.
wilandlane likes this.
vasava is offline   Reply With Quote
Old   October 24, 2016, 10:26
William
That works perfectly, Vasava!
I was trying to use the existing solid body within SpaceClaim/Fluent, but this is much easier.
part, post-processing, showing, solid, zone
Tips of ICEM CFD meshing speed up CFD_D_BOY ANSYS Meshing & Geometry 1 September 7, 2011 03:53
Complex .stl data for volume meshing in ICEM CFD Nils_H ANSYS Meshing & Geometry 5 September 2, 2011 09:39
How to visualize Output Equation Residuals in CFD Post rubin4ik CFX 2 June 22, 2011 07:37
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 13:23
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 07:41
