[ANSYS Meshing] Bodies of Influence Settings / Problem
Like Tree3Likes
  • 3 Post By cycleodyssey
Old   January 11, 2012, 07:21
Default Bodies of Influence Settings / Problem
Phil
cycleodyssey is on a distinguished road
Hi, I have just a question about bodies of influence. I am having trouble getting them to work when the body of influence is totally inside the scoped body, i.e see attached picture with internal box (which i am unable to replicate..) I can only use body of influence when at least some part of the body of influence is outside the body that it is scoped to- which means its poor for using on wake mesh control for 3d models... Any ideas of how to solve this??
Regards,
File Type: jpg 02-CFD-Body-Sizing-using-Body-of-Influence.jpg (18.3 KB, 256 views)
cycleodyssey is offline   Reply With Quote
Old   January 11, 2012, 17:57
Default Problem solved...
Phil
I have (perhaps!!) solved this problem. For reference the method that i used is:
The target body that you want to scope to needs to be selected as patch conforming tetrahedron - if you don't do this it will not modify the meshing (To make target body patch conforming right click on mesh, select insert -> method -> select target body --> then select method tetrahedron)
Any suggestions please feel free, cheers
DAPHNE, sherlock and lape95 like this.
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
conduction problem venkataramana OpenFOAM 3 December 1, 2013 08:30
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
CFX new user, problem with solver and PRE settings Vijesh Joshi CFX 1 March 13, 2006 23:42
