January 4, 2012, 05:38 |
Rotate and revolute possible ?
Ijaz
Rep Power: 14 |
How do i make the part rotate and revolute abt an axis? My problem statement is tool (smaller cylindrical part)needs to rotate by itself as well as rotate around (0,0,0) axis inside another cylinder containing water.I need to see the pressure and velocity variation as the tool moves itself as well as around the axis. Please suggest me how to do it step by step. Also do additional surfaces need to be drawn in gambit so that I can get better display of result in 3d as I need to see the pressure variation of water in the tank at various heights..
January 4, 2012, 06:01 |
Maxime Perelli
Rep Power: 41 |
can you post a sketch of what you want to build?
In memory of my friend Hervé: CFD engineer & freerider |
January 4, 2012, 06:31 |
Kaushik
Rep Power: 15 |
It is similiar to the slotted cylinder problem but I need the cylindrical tool in my case to rotate and revolute. Please help me step by step. Also had a doubt in the meshing...I have multiple corner points when I use the fixed or proximity size function i am not able to concentrate the meshing at the gaps/corners..My fig is as folllows
January 4, 2012, 06:35 |
Maxime Perelli
Rep Power: 41 |
First the design: what do you want exactly?
I don't understand the rotate and volute construction. Do you mean like a spring?
January 4, 2012, 06:41 |
Kaushik
Rep Power: 15 |
No not like a spring..
I used the sliding mesh shown in figure to only rotate my tool (cylinder with slots) but now I have to make the tool also revolute around the centre axis..(0,0,0). The tool is placed eccentrically at position (0,-1.5,0.8). I hope i make my doubt clear to you.. |
January 4, 2012, 07:51 |
Maxime Perelli
Rep Power: 41 |
so you don't need to construct any geometry.
It is only the motion you want to describe?
January 4, 2012, 09:13 |
Ijaz
Rep Power: 14 |
yes..can we do it in fluent itself or there needs to be some changes in geometry in gambit?
January 4, 2012, 09:18 |
Maxime Perelli
Rep Power: 41 |
Basically you don't to do something in Gambit, except if you want to work with layering
January 4, 2012, 09:34 |
#9 |
Ijaz
Rep Power: 14 |
So could you tell an easy method to perform the motion because I give motion to the rotor domain in sliding mesh formulation which to rotate about its own axis. Then for revolution what can be done. Since I wanted both motions simulatneously..is it a tedious process?
January 4, 2012, 09:40 |
#10 |
Maxime Perelli
Rep Power: 41 |
what is exactly your motion?
a cylinder is rotating around its axis, and the axis is also rotating?
January 4, 2012, 11:09 |
#11 |
Ijaz
Rep Power: 14 |
yes sir..the axis rotates abt (0,0,0) /
January 4, 2012, 11:19 |
Embedded Reference Frames
#12 |
This problem can be classified as Embedded Reference Frames and can be solved by two methods:
1. Steady State Multiple Reference Frame (MRF) Modeling 2. Sliding Mesh ---> However for this method you need UDF (I shall share this along with sample mesh files, boundary conditions, sample solution and other helping material) First you must decide which method you would prefer. If I were you I would have choose the first method and later on move to later method if needed. |
January 4, 2012, 14:59 |
#14 |
Ijaz
Rep Power: 14 |
thks for your time...yes sir it is similiar to the picture you provided.. i am doing a 3d geometry with submerged cylinder ..ill use steady mrf...can u suggest the methodology ...
January 5, 2012, 16:35 |
#15 |
Ijaz
Rep Power: 14 |
far...can you give more info on how to embedded ref
frame motion? |
January 20, 2012, 05:12 |
#17 |
Ijaz
Rep Power: 14 |
I did as you said and made my slotted cylinder walls as interfaces but there are some problems..there are more than 18 faces which I need to make as interfaces...is that right? My geometry is attached herewith
http://www.mediafire.com/?7uho78575kbfap8 The flow is not observed near the slots...could you help me with the meshing of the volume meshing please..the tool is of r=0.285m and ht 0.4m and slots r=0.02m placed in a tank of r=2.6m,h=3.2. The tool is placed at z=0.8m from top of tank and y=-1.5 Last edited by Ijaz; January 24, 2012 at 02:36. |
January 24, 2012, 20:54 |
#18 |
Ijaz
Rep Power: 14 |
Please help me in solving the meshing near the slots because flow near the slots is not differentiated with respect to the other cylindrical surfaces. Kindly help.
January 27, 2012, 00:36 |
#20 |
Ijaz
Rep Power: 14 |
Thanks...i am eagerly waiting for your reply..
[ANSYS Meshing] meshing for rotate and revolute | Ijaz | ANSYS Meshing & Geometry | 0 | December 25, 2011 17:51 |
