[ANSYS Meshing] Fine meshing in ANSYS Meshing v13
Like Tree1Likes
  • 1 Post By PSYMN
Old   November 30, 2011, 04:07
Default Fine meshing in ANSYS Meshing v13
shoeb khan
shk12345 is on a distinguished road
Hello friends
I am new in Ansys Meshing v13 .
I want to know what are the different ways to make a fine mesh from a course mesh.
How to make a fine and very fine mesh.
i have a 3D geometry to mesh .
Thanks in advance
SHK
shk12345 is offline   Reply With Quote
Old   December 1, 2011, 11:41
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
In the main Meshing Details window, the top field is a slider called "relevance". Relevance can be slid to the right to refine the whole model. Note, this refines all the mesh settings... The mesh then needs to regenerate.
Since you are in Workbench, you can actually use the little check box and parameterize this or other mesh settings. Also parameterize the statistics (at the bottom of the mesh details panel) for number of elements and min quality. Then you can go to the parameter set manager and run a series of what if trials that will update your project (mesh refinement and solver runs) in batch with a variety of mesh sizes. Turn on "retain design points" if you want to keep all the files.
You could even control this with ANSYS DesignXplorer and get some nice charts about mesh sensitivity and correlation, etc.
ashraf88 likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
FATAL meshing error in ANSYS Abdulaziz Rajab Main CFD Forum 15 April 26, 2014 06:01
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
[ANSYS Meshing] ANSYS meshing crash when started robert86 ANSYS Meshing & Geometry 1 March 16, 2011 05:47
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 13:09
ANSYS ICEMCFD Streaming Meshing Demos ANSYS Main CFD Forum 2 October 22, 2004 08:55
