[GAMBIT] gambit 2.3.16 on ubuntu 10.04
Like Tree4Likes
  • 4 Post By villager
Old   November 29, 2011, 05:51
Default gambit 2.3.16 on ubuntu 10.04
binjiestudent is on a distinguished road
Hello everyone
May be there have something wrong when the gambit 2.3.16 run on the ubuntu 10.04,some questions as flows:
  1. when i run the gambit,one warning is given,but the gambit can run normally:
warning: locale not supported by C library, locale unchanged
VisualID: 209
class: 4
depth: 24
bits_per_rbg: 8
map_entries: 256
Using OPENGL_DEVICE_DRIVER with no standard visual.
2. when i create two volume and then do boolean operation,at this time,gambit crumbled and closed automaticly ,at the same time ,terminal apperaed message as flows:
Received exception: SIGSEGV (segmentation violation)
Please send the GAMBIT.8073/jou and GAMBIT.8073/trn files to your local
Fluent office or distributor. Also send a message including any
relevant errors or warnings you see above in this window. You may
wish to delete the temporary directory GAMBIT.8073 after sending the
above files.
3.when i create two volume and try to use shift+leftkey to pick them, the ubuntu system like dead,you can do any operation.after 5min. the system to be oK ,but the same question apperaed once use shift+leftkey
Does anyone meet these questions like me ? and how to slove?
binjiestudent is offline   Reply With Quote
Old   December 5, 2011, 10:17
Default Hi
bachasaurus is on a distinguished road
hello
Can you pass the gambit 2.3.16 installer for linux?
I want to use in Debian
r
egards
bachasaurus is offline   Reply With Quote
Old   February 29, 2012, 10:12
Smile ...
vlg
villager is on a distinguished road
Originally Posted by binjiestudent View Post
Hello everyone
Yes, I finally have managed with this error.
If you recieve such messages in console:
Received X Intrinsics Warning <Cannot convert string "-adobe-helvetica-medium-r-normal-*-*-120-75-75-*-*-*" to type FontStruct
and other such messages, and Gambit crashes after trying to mesh (for example:
volume mesh volume.1 tetrahedral
then, install some packages: (Ubuntu, insert these lines in console - bash)
sudo apt-get install xfonts-75dpi
sudo apt-get install xfonts-100dpi
sudo apt-get install mesa-utils
sudo apt-get install libxtst-dev
Then edit xorg.conf;
sudo nano /etc/X11/xorg.conf
insert these strings:
Section "Files"
FontPath "/usr/share/X11/fonts/misc"
FontPath "/usr/share/X11/fonts/cyrillic"
FontPath "/usr/share/X11/fonts/100dpi"
FontPath "/usr/share/X11/fonts/75dpi"
EndSection
press Ctrl-O to save, ENTER. Then Ctrl-X to quit "nano" text editor.
At last, execute this line:
sudo dpkg-reconfigure -phigh xserver-xorg
and restart your computer. (you can restart only xserver if you don't want to restart your computer)
Now, I think only packages xfonts-75dpi xfonts-100dpi are necessary, other packages can be installed optionally. You can check it
NOTE: I've started Gambit with X11 display driver!!!
gambit -dev X11
villager is offline   Reply With Quote
Old   April 18, 2012, 02:18
Smile it solve my problem.
Li JIachun
saimachensi is on a distinguished road
I have the same error message but with different problem. My gambit crashes whenever I try to import some geomery files. I do what
villager says, my problem solved. Thanks.
saimachensi is offline   Reply With Quote
Old   October 27, 2013, 20:28
Default the same problem
Flavio
hfla is on a distinguished road
Hello, I have the same problem for gambit on ubuntu 13.10.
"locale not supported by C library, locale unchanged".
Gambit crashes when I split an edge and in general continuslly. Have somebody fix the problem?
Thanks Flavio
hfla is offline   Reply With Quote
Old   October 28, 2013, 09:17
Lightbulb answer
vlg
Thanks Flavio
Flavio, have you read these two posts and carefully done all instructions?
http://www.cfd-online.com/Forums/ans...tml#post346899
http://www.cfd-online.com/Forums/ans...tml#post415970
If so, let me know of any issue.
Old   October 28, 2013, 10:55
Default It seems works well
Flavio
Thanks a lot for the answer, I applied the fixes you say in this thread. Also I applied what you say in "Gambit works on Windows, but not in Linux", with the creation of a .C file. It seems work well, I created a grid without a crash , but the error on startup is the same:
There is a think I don't understand, I compiled the file memcpy_preload.c on my Deskotp, and I created the .so file there. Is there a specific location for .so file? Now everytime I'm going to start gambit I must digit
LD_PRELOAD=......../memcpy_preload.so ......../gambit -dev X11
or I can start gambit from every folder i like with
gambit -dev X11
Thanks for your patience
Old   October 28, 2013, 13:32
Smile
vlg
1)
... but the error on startup is the same:
That's not error, just warning I usually ignore this.
2) make a file:
:~$ sudo gedit /usr/bin/gambit
Content:
#!/bin/sh
LD_PRELOAD=***FULL PATH TO memcpy-preload.so*** ***FULL PATH TO GAMBIT*** -dev X11
:~$ sudo chmod +x /usr/bin/gambit
Exclude path to gambit_dir/bin/gambit from your system PATH variable (if you did it to run gambit from every folder you like). Restart terminal.
You should get this output:
:~$ which gambit
/usr/bin/gambit
Then, you start gambit like this:
:~$ gambit
P.S. "-dev OpenGL" works fine for me too.
Maybe, you need mesa, to run like that.
For Debian-like linux distros:
:~$ sudo apt-get install mesa-common-dev mesa-utils libglu1-mesa-dev
Last edited by villager; November 15, 2013 at 11:40. Reason: improved code formatting for better understanding
Old   October 28, 2013, 17:44
Default gambit start
Flavio
Hello, I followed your instructions, but I'm sure that I made a mistake. I create the file with:
I write in gedit:
#!/bin/sh
LD_PRELOAD=~/Desktop/memcpy-preload.so ~/Fluent.Inc/bin/gambit -dev X11
Now I save and close the gedit file. So I turn back to the terminal for writing:
.I don't get any output of errors or warning, but when I close the terminal and reopen I don't get the messagge;
which gambit
I think that could been importat to know that when I installed FLuent and gambit, for starting from any folder I like, I wrote the bashrc in my home folder:
gedit ~/.bashrc
by editing in the end of the file the string:
PATH=~/Fluent.Inc/bin:$PATH ; export PATH
so I saved and closed the gedit. On the terminal I inserted:
source ~/.bashrc
It could been this the problem?
Thanks a lot
Old   October 29, 2013, 07:21
Default Solved
Flavio
Thanks a lot Villager, I've changed the name of the gedit file into gambitst with:
sudo gedit /usr/bin/gambitst
So I followed your instruction, and now everything works fine. Thanks a lot
I've the last question, when I start Gambit I receve that message:
Warning: locale not supported by C library, locale unchanged
	Using X_DEVICE_DRIVER with standard visual.
Total of 1.48 cpu second(s), 623456 maximum memory.
what the means of "Using X_DEVICE_DRIVER with standard visual, and Total of 1.48 cpu second(s), 623456 maximum memory"?
Thank you
Old   December 4, 2013, 04:47
Phoevos
fivos is on a distinguished road
Villager thank you a lot for your detailed instructions and efforts. Gambit works!!!
fivos is offline   Reply With Quote
Old   March 18, 2014, 08:31
Issac
gindar is on a distinguished road
It works. My OS is ubuntu 13.10.
Thanks a lot!
gindar is offline   Reply With Quote
Old   February 28, 2017, 01:03
Question Error while installing Gambit on ubanu 8.10
  #13
JSR
Jaijeet
JSR is on a distinguished road
I am new to ubantu, I have install gambit but when i run it from /home/fluent.inc/bin gambit -dev11 it shows --jaijeet@jaijeet-laptop:~/gambit_install/Fluent.Inc/bin$ gambit -dev x11
The program 'gambit' is currently not installed. You can install it by typing:
sudo apt-get install gambit
bash: gambit: command not found
  • but when i use ./gambit it shows
jaijeet@jaijeet-laptop:~/gambit_install/Fluent.Inc/bin$ ./gambit
This product has the following patch(es) applied:
patch_2230_1
You can find more information about the patch(es) in the
respective text file(s) located at:
/home/jaijeet/gambit_install/Fluent.Inc/gambit2.2.30.
Starting /home/jaijeet/gambit_install/Fluent.Inc/gambit2.2.30/lnx86/gambit ...
Locking assertion failure. Backtrace:
#0 /usr/lib/libxcb-xlib.so.0 [0xb21007c7]
#1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_unlock+0x31) [0xb2100891]
#2 /usr/lib/libX11.so.6(_XReply+0x254) [0xb23ce494]
  • till now i have untar the file...then install the .sh file in seperate file....the go to installed directory fluent/bin......and the run the gambit using ./gambit or gambit -dev x11
  • may be my procedure is not right
  • please help me...my project is delayed by 4 months in facing this shit.....
JSR is offline   Reply With Quote
Old   February 28, 2017, 15:39
vlg
maybe, you've forgotten one more slash
/home/fluent.inc/bin/gambit -dev11
(Suprised, if anyone uses gambit in 2017)
ubuntu gambit2.3.16
[GAMBIT] GAMBIT 2.4.6 on Ubuntu 10.04 DoHander ANSYS Meshing & Geometry 29 May 22, 2012 07:37
Gambit error in Ubuntu 9.10 jbmere FLUENT 1 November 20, 2011 16:00
Uninstall Gambit on Ubuntu 10.04 ClothMelon FLUENT 0 December 6, 2010 15:19
ANSYS FLUENT 12.1.4 on ubuntu 10.04 mundhwam FLUENT 0 June 28, 2010 16:34
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 13:39
