[GAMBIT] problem uniting meshed faces from two different volumes
Like Tree1Likes
  • 1 Post By -mAx-
Old   November 23, 2011, 17:49
Question problem uniting meshed faces from two different volumes
alejandro alonzo garcia
alejandro_1980 is on a distinguished road
Send a message via MSN to alejandro_1980
I m trying to unite two meshed volumes ...(a cilindrical hole located in a flat 3d plate, and a cylinder, the cylinder has exactly the size of the hole).... both the hole of the plate and the cilinder have same common meshes (two identical meshes, one from the cylinder and one from the hole....)
I couple both meshes in the convenient place... i reorient the mesh because i want connect all faces from both volumes, and then i pug the meshes and export them to fluent...
when i read the mesh in fluent, i can see that the meshes are not coupled, i can fuse those faces but it deforms the mesh, it is easy to create a interface but i dont know about the numerical consequence...
when i zoom in the geometry in fluent i can see that one meshed face have little diferences (very tiny) in his positions respect the other common meshed face.. i think it is a problem with the tolerances.. but.. what can i do in gambit to fix this problem?? does any one could help me?? my best regards =)
alejandro_1980 is offline   Reply With Quote
Old   November 24, 2011, 04:21
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
in gambit you can connect your surfaces with the riske that you loose one of your volume mesh.
Then you need to remesh.
In Fluent you can use the interfaces. Since meshes are the same you won't have any numerical issue.
Else it seems to heva another method, but never used it: http://cdlab2.fluid.tuwien.ac.at/LEH...ug/node138.htm
alejandro_1980 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 24, 2011, 04:38
thank you max.. i have been feeling sleepless for that little problem.. my best regards... one annotation.. --->Since meshes are the same you won't have any numerical issue.................
you refer to the same meshes as the same contact face meshes from the two different volumes... thats right?
sorry but I'm not thinking straight...
Old   November 24, 2011, 04:41
-mAx-'s Avatar
Maxime Perelli
yes: if both interfaces meshes are the same, you shouldn't hqve qny issue
face, gambit, unwanted
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
[gambit] problem connecting faces on 2 volumes joe_star ANSYS Meshing & Geometry 1 December 16, 2009 03:38
[Commercial meshers] problem meshing two interacting volumes banerji OpenFOAM Meshing & Mesh Conversion 0 December 14, 2009 16:59
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 23:54
