[GAMBIT] Gambit works on Windows, but not in Linux |
Rep Power: 15 ![]() |
Hi all,
I installed Gambit on both Windows 7 and Linux (Red Hat 5.7) machines, with the Linux being the license server. When running Gambit on Windows, it starts and works perfectly. But when I'm starting it on the Linux machine, I get the following message: ------------------------------------------- LANG en_US.UTF-8 changed temporarily to C for gambit use. Starting /ansys_inc/v130/Gambit/Fluent.Inc/gambit2.4.6/lnx86/gambit ... Gambit build SP2007051420. Received exception: SIGSEGV (segmentation violation) Please send the GAMBIT.20053/jou and GAMBIT.20053/trn files to your local Fluent office or distributor. Also send a message including any relevant errors or warnings you see above in this window. You may wish to delete the temporary directory GAMBIT.20053 after sending the above files. ERROR: Please retain a copy of the GAMBIT.20053/jou, GAMBIT.20053/trn, and GAMBIT.20053/*.dbs files, any imported geometry and any relevant errors or warnings you see above in this window and contact support at your local Fluent office or distributor. Segmentation fault --------------------------------------------- It's not an issue of the *.lok file, as I haven't worked on any geometry, but only started Gambit for the first time. Any help will be appreciated!! Victor. |
vlg
Rep Power: 18 ![]() |
I has such problem (the same error on trying to mesh the model) on every computer with Ubuntu too, except my home computer... It's a kind of magic
![]() Many people asked similar question, but never found the answer, i guess. for example, here http://www.cfd-online.com/Forums/flu...tal-error.html and, maybe, here, because author didn't report any further acknowledgment. http://www.cfd-online.com/Forums/flu...or-gambit.html It would be great, if somebody got it through. |
I solved the problem by installing a library that was missing (libXm.so.3 which is a part of openmotif) on my RedHat Linux machine. However, my issue was that I couldn't run Gambit at all, rather than having trouble during meshing or geometry changes.
I think that the Gambit (or ANSYS) experts are so "quiet" about these problems because they do not provide support any more, and suggest using other meshing programs, such as ICEM or ANSYS meshing. |
#4 | |
any luck solving this problem? I am facing the same issue. I can't mesh face or volume. any suggestions will be appreciated ! |
vlg
Good day. It seems like the problem is solved.
Part1. Read this http://www.cfd-online.com/Forums/ans...tml#post346899 Still crashing? Part2. on Debian-like: Code:
sudo apt-get install libc6-dev-i386 Different Linux? Reference to: Choose yours package with stubs-32 Create file memcpy_preload.c Code:
/* Copyright (C) 2011, Aurelien Jarno <aurelien woof-woof aurel32 dot net> This program is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version. This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more details. You should have received a copy of the GNU Lesser General Public License along with the GNU C Library; if not, write to the Free Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA. */ #include <dlfcn.h> #include <stdint.h> #include <stdio.h> #include <stdlib.h> #include <string.h> #include <syslog.h> #include <sys/time.h> void *memcpy(void *dst, const void *src, size_t n) { #ifndef NOLOG uintptr_t usrc, udst; /* Convert to unsigned as arithmetic on pointer is undefined */ udst = (uintptr_t) dst; usrc = (uintptr_t) src; /* Check if source and destination overlap */ if (((udst < usrc) && ((udst + n) > usrc)) || ((usrc < udst) && ((usrc + n) > udst))) { static time_t lastlog = -1; struct timeval tv; /* gettimeofday() is not expensive for the conditions we target in * the Debian package (kernel >= 2.6.26, x86-64 architecture), this * might need to be changed if this wrapper is later needed with * different conditions */ gettimeofday(&tv, NULL); /* Don't spam syslog, limit to (roughly) one log entry per second. */ if (tv.tv_sec > lastlog) { lastlog = tv.tv_sec; syslog(LOG_WARNING | LOG_USER, "source and destination overlap in memcpy() at ip %p", __builtin_return_address(0)); } } #endif /* Call memmove() instead of memcpy() */ return memmove(dst, src, n); } Code:
gcc -D_GNU_SOURCE -DNOLOG -O2 -Wall -fPIC -shared -m32 -o memcpy_preload.so memcpy_preload.c Run with Code:
LD_PRELOAD=......../memcpy_preload.so ......../gambit -dev X11 Don't mind these lines during run ERROR: ld.so: object '....../memcpy-preload.so' from LD_PRELOAD cannot be preloaded: ignored. Originally this part of solution was provided on FedoraForum: http://forums.fedoraforum.org/archiv.../t-256522.html It perfectly works for me. Last edited by villager; March 27, 2013 at 03:59. |
hi guys
you're all lucky guys having that rare linux 64/32 version of gambit I'm switching all the time between windows(meshing with gambit 2.3.16 win version) then loading the mesh in fluent 6.3.26 on linux since fluent runs smoothly on linux 64.... I wish I had a linux version of gambit for my final project, help please. best regards, |
hi guys
I followed the fix brought to us by Villager, but no way to get it working on gentoo 64 bit, actually I did compile the memcpy_source.c and added the LD_preload directive, it still cash with that ver same error message displaying a popup message box on say that gambit cannot continue.... here is the terminal's output: $ gambit -dev x11 LANG en_US.UTF-8 changed temporarily to en_US for gambit use. Starting /home/unleashed/Fluent.Inc/gambit2.4.6/lnamd64/gambit -device x11... ERROR: ld.so: object 'memcpy-preload-64.so' from LD_PRELOAD cannot be preloaded: ignored. Gambit build SP2007051420. Using X_DEVICE_DRIVER with standard visual. Received X Intrinsics Warning <Cannot convert string "-adobe-helvetica-medium-r-normal-*-*-120-75-75-*-*-*" to type FontStruct>. Received X Intrinsics Warning <Cannot convert string "-adobe-helvetica-bold-r-normal-*-*-120-75-75-*-*-*" to type FontStruct>. Received X Intrinsics Warning <Cannot convert string "-adobe-helvetica-bold-r-normal-*-*-120-*-*-*-*-*" to type FontStruct>. Received X Intrinsics Warning <Cannot convert string "-adobe-courier-medium-r-normal-*-*-120-*-*-*-*-*" to type FontStruct>. Received X Intrinsics Warning <Cannot convert string "-adobe-courier-medium-r-normal-*-*-120-75-75-*-*-*" to type FontStruct>. Received X Intrinsics Warning <Cannot convert string "-adobe-helvetica-medium-r-normal-*-*-120-*-*-*-*-*" to type FontStruct>. Received exception: SIGSEGV (segmentation violation) Please send the GAMBIT.32409/jou and GAMBIT.32409/trn files to your local Fluent office or distributor. Also send a message including any relevant errors or warnings you see above in this window. You may wish to delete the temporary directory GAMBIT.32409 after sending the above files. this error occurs in a systematic way when I try to mesh geometry or import a mesh file I compiled the memcpy source once with the -m32 flag and then without since I have 64 bit one, I taught it was an architecture issue??? ![]() please help me out, this's what I call a CFD nightmare Last edited by QBeast; April 14, 2013 at 20:32. |
#9 | ||
the fix works on gentoo 64 bit, it needs some fonts as with ubuntu
for gentoo it's adobe 75dpi and 100dpi : compiled the source memcpy-preload.c given by villager without the -m32 flag. it works, gentoo is likely to include prerequisite headers, they were already there on mine: Code:
$gcc -D_GNU_SOURCE -DNOLOG -O2 -Wall -fPIC -shared -o memcpy-preload-64.so memcpy-preload.c Code:
#emerge x11-libs/motif #ln -s /usr/lib/libXm.so.4 /usr/lib/libXm.so.3 #cp memcpy-preload-64.so /usr/lib64 # emerge media-fonts/font-adobe-75dpi media-fonts/font-adobe-100dpi then went here: http://en.gentoo-wiki.com/wiki/X.Org/Fonts and got the files settings section pasted in /etc/X11/xorg.conf file : Code:
# ********************************************************************** # Files section. This allows default font and rgb paths to be set # ********************************************************************** Section "Files" # The location of the RGB database. Note, this is the name of the # file minus the extension (like ".txt" or ".db"). There is normally # no need to change the default. # RgbPath "/usr/share/X11/rgb" # Multiple FontPath entries are allowed (which are concatenated together), # as well as specifying multiple comma-separated entries in one FontPath # command (or a combination of both methods) # # FontPath "/usr/share/fonts/misc/" # FontPath "/usr/share/fonts/TTF/" # FontPath "/usr/share/fonts/OTF" FontPath "/usr/share/fonts/Type1/" FontPath "/usr/share/fonts/100dpi/" FontPath "/usr/share/fonts/75dpi/" # FontPath "/usr/lib/X11/fonts/local/" # FontPath "/usr/lib/X11/fonts/misc/" # FontPath "/usr/lib/X11/fonts/75dpi/:unscaled" # FontPath "/usr/lib/X11/fonts/100dpi/:unscaled" # FontPath "/usr/lib/X11/fonts/Speedo/" # FontPath "/usr/lib/X11/fonts/Type1/" # FontPath "/usr/lib/X11/fonts/TrueType/" # FontPath "/usr/lib/X11/fonts/freefont/" # FontPath "/usr/lib/X11/fonts/75dpi/" # FontPath "/usr/lib/X11/fonts/100dpi/" # The module search path. The default path is shown here. # ModulePath "/usr/lib/modules" EndSection Quote:
then su: Code:
#env-update #source /etc/profile Quote:
Great thanks to all of you, special thanks to Mojtaba.a, thanks Villager. |
gambit, linux, meshing, windows |
Windows to Linux => END problems... | zboud | CFX | 4 | February 4, 2010 16:53 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
Is the fluent mesh generate in windows can be used in linux? | panda60 | OpenFOAM | 7 | October 19, 2009 11:51 |
UDF error from Windows to Linux | manu | FLUENT | 3 | January 10, 2008 04:02 |
loading FLUENT 6.2 and GAMBIT on Red Hat LINUX | Kiran | FLUENT | 1 | October 16, 2007 09:12 |
