[ICEM] How to create non-comformal mesh at the interface of two blocks? |
September 6, 2011, 00:27 |
Rep Power: 17 |
As showed in the attached figure, I put the inner and outer blocks into different parts. I want to apply different mesh densities for the inner and outer blocks, ie, how to break the connecticity between these two block?
Thanks for your help! Last edited by bluelc; September 6, 2011 at 03:54. |
September 6, 2011, 09:47 |
Multiple domain with nonconformal grids interface
Rep Power: 17 |
1. Initialize the block for the first domain, associate interface edge with curves(interface_1), define pre-mesh parameters and convert the pre-mesh to unstrutural mesh;
2. Right click Blocking/Topology and create sub-topo. Re-initialize the block for the second domain using a new part, associate interface edge with curves(interface_2), … then convert the pre-mesh to the unstrutural mesh. Select merge for the popup window. 3. Interface_I and interface_2 are different parts but identical in geometry feature in ICEM and a coupled interface boundary in fluent. 4. Define boundary conditions and output the mesh. Done. Wish this can help someone in the future. |
February 28, 2012, 11:12 |
thanks
Rep Power: 17 |
hi blue,
thanks for posting ... very useful, helped me out of a tight situation - much appreciated ... cheers jonathan |
September 26, 2013, 23:59 |
liuyan
Rep Power: 13 |
can you upload the .block and .tin file? bluelc
thanks |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Mesh motion applied to an internal interface | lr103476 | OpenFOAM Running, Solving & CFD | 6 | March 12, 2008 22:07 |
