May 17, 2011, 10:00 |
Various errors in importing geometry
Rep Power: 15 |
Hi everybody, i just need your help.
I know the problem could be banal, but i can't get out of it. So, I just passed from Ansys 11 to 13, and immediatly I had some problems with Icem. I'm trying to import a Parasolid geometry (x_t) (tried to create it by using different modelers, as SolidWorks, Ansys DesignModeler), gave the .tin file the same directory of the Parasolid file, but when importing Icem says: The tetin file aaaaa.tin does not exist. So, I tried to import an IGES file too, but after the creation of the .tin file Icem says: can't read surface model. I really don't know what to do, I tried many times but never obtained some results. I hope someone can find a solution for my problem, thanks. E.C. |
May 18, 2011, 11:50 |
write permissions?
Simon Pereira
Rep Power: 47 |
Sorry, not enough info. Parasolid import works for me.
Usually this sort of issue is due to ICEM CFD not having write permissions in the folder. The converter can't put the tetin file in the folder, so it doesn't find it for the import. Simon
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
May 18, 2011, 19:25 |
Rep Power: 15 |
Inspired by your suggestion I tried to load the file from different directories, and in some of then Icem can write the tin file and then load it.
It's a bit strange because I don't remember I set particular permissions to folders, however now it works. Sorry once more for the banality of the question, but your post gave me the help I needed Thanks. |
May 26, 2011, 01:46 |
Write permission error
Mohammad Naim
Hi guys,
I am new to the whole CFD environment and often when I try to import geometry from solidworks (parasolid format) into ICEM a write permission error comes up. it goes something like this: An internal error has occured: could not read "./fairing and wheel.tin": permission denied you can report the error to the maintainers of this software, skip the error and continue working, or view a stack trace. Now, when i click continue i don't see any geometry getting imported. This does not occur all the time which is why i am puzzled. Is there a problem with the way i am saving the file in solidworks? How do i fix this problem? Any help would be much appreciated Cheers |
May 26, 2011, 06:11 |
Vijaya Sekhar Gullapalli
Rep Power: 15 |
Parasolid import into ICEM is not free in v13 as it is in v11. Your need to have one paralsoid import license to ICEM that is not relatively inexpensive. You can however translate the agdb file from design modeler to ICEM via CFX mesh.
May 27, 2011, 22:31 |
Simon Pereira
Rep Power: 47 |
Acis (*.sat) is free in ICEM CFD, can you output that from Solidworks?
May 30, 2011, 04:11 |
Rep Power: 15 |
December 9, 2011, 15:01 |
#8 | |
Kyle
Rep Power: 14 |
July 17, 2012, 05:37 |
#9 |
abdul
Rep Power: 14 |
January 20, 2016, 10:42 |
Update
#10 |
Bruno F. Porto
I know this discussion is old but I had this problem and the solution and cause are different from the examples here.
In may case the problem was because of the file name of the imported geometry that had an speacial caracter: peça1.igs When I exported (from SolidWorks) to a file name without the "ç", in this example "peca1.igs" this problem was gone. Thank you for the help as it helped a lot to solve this issue. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
