[ICEM] tube with 45 degree inlet
Like Tree3Likes
  • 1 Post By germangsilva
  • 1 Post By faee0
  • 1 Post By saisanthoshm88
Old   May 4, 2011, 17:08
Default tube with 45 degree inlet
Germán González Silva
germangsilva is on a distinguished road
Send a message via MSN to germangsilva
hello all,
I made ​​the mesh for this geometry, but I am getting negative values ​​of angle and determinant .
1 - I created a block to the main cylinder, then made ​​two cuts near the side inlet, I associate the edges with the inlet and outlet tube
2 - I extruded the block side entrance with a line and point and extruding block association with inlet inclined at 45 degrees.
3 - I drew the Ogrid at the entrance angle to the opposite wall of the tube (diameter) and another ogrid along the main pipe. For the main Ogrid, I chose the inner block crossing between the two Ogrid.
4 - I realize the division of volumes in the edges.
how do I make the distribution of blocks? , which would be the best topology?
Best regards.
Attachment 7559
Attachment 7560
mesh.zip
saisanthoshm88 likes this.
germangsilva is offline   Reply With Quote
Old   May 6, 2011, 08:30
william
faee0 is on a distinguished road
maybe you can split block like this.
germangsilva likes this.
faee0 is offline   Reply With Quote
Old   May 6, 2011, 09:23
saisanthoshm88 is on a distinguished road
Hi hook,
Can you please upload your block file here.
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   May 6, 2011, 12:52
Hi hook,
thank you very much for your time and response. I want to understand what you make.
You made ​​three splits at the side entrance, associated with the two semi-ovals in different blocks. Ogrig Fianalmente you defined with the demi-oval block smaller.
Could you upload the archibo block?
Thanks in advance
Old   May 9, 2011, 05:01
Hi germang,
The curve at the side entrance is better captured with an additional split there ( Look into the image sideentrance.jpg) and then you dont need to have two seperate O- grids ( As said in your 3rd step). Select all the blocks and the faces through which the O- grid has to pass ( Look into the image FacesforO-grid.jpg).
Before making the O- grids go to edit associations and snap project all the vertices .When you're done with the O- grids adjust some inner O-grid vertices where ever required. This will yield you a better mesh and shall eliminate the negative quality elements. pre mesh smoothing can improve the quality further.
Hope this helps!
Best regards,
Santhosh.
pressure inlet for shock tube!!! showwa FLUENT 0 December 24, 2008 03:10
Duct Flow with 90 degree inlet and outlet k FLUENT 3 August 19, 2007 15:30
BC at the inlet of a tube Jackie Main CFD Forum 11 July 29, 2003 12:57
Parabolic temperature Inlet Profile in a tube majestywzh FLUENT 0 April 9, 2003 07:37
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
